How do I reset ECU 91 Lego?
Just replaced leaking upper radiator hose, added pre-mixed coolant and the air has been purged from the coolant system, during purging process, CEL appeared. How do I retrieve the code and clear the ECU? Searches of this database couldn't find ecu code instructions.
New user just wants the CEL to go away.
  wtdash said:
From Legacy Central (they deal specifically w/the '90-94 Legacy):
http://legacycentral.org/library/literature/codes.htm
You should also be able to just disconnect the negative battery cable for 1 hour, but not sure if this completely clears the codes or just resets the ECU (not the same thing).
Good luck!
Thanks for the information; I ended up disconnecting the battery and after about 1 hour, the CEL went away, and now the radiator cooling fans aren't running continuously and the engine stopped running rich. :banana:
