plug wires
I want to get a decent set of plug wires for my Brat but I'm not sure what to get. I have the SPFI conversion and also have 3-4" of lift. The ones I have are working ok but I don't know what they were actually bought for. And the coil wire is a little short do to the lift. So what would I be looking for....What brand and what model car do I order them for? Thanks!
if you're looking for high quality wires - go with Magnecor, they are awesome. i put them in every vehicle i own and have put 150,000 miles on one set before.
you might even be able to ask about checking the length of the coil wire or supplying you with a longer one.
or take your wires to Subaru and compare the lengths, particularly the one for the coil.
can you just move the ignition coil, make a little bracket adapter or something?
Yeah I could probably move it a little. That would help. So magnecor.... I didn't know they made them for old school cars.
An EA82 set will work fine. The lengths should be largely the same. As for your coil wire - I sugest you relocate the coil. I put the SPFI coil on the drivers side where it's located on the EA82's as that allows you to use the EA82 coil wire.
Do you by chance have any pics of where to put the coil on the drivers side? Thanks!
