unibrook Posted December 18, 2008 Share Posted December 18, 2008 Can you just use the tools included with the Hub Tamer to remove the rear hub on a Forester 2001? Or do you have to use a slide hammer? Can't seem to tell if the rear hubs are floating or trapped. Does anyone know? Link to comment Share on other sites More sharing options...
hohieu Posted December 19, 2008 Share Posted December 19, 2008 (edited) The rear hubs are pressed into the inner races of the wheel bearing, the only thing holding it in the housing is the axle nut. The floating rotor (or drum) then slides onto the studs attached to the hub. Theres a big attachment included in the tool kit for removing the hub, but it doesn't really work for the rear. It is designed for front wheel drive cars so I imagine it would work for the front hub. A slide hammer and adapter would be ideal, but I tapped the hub out from the inside with one of axle puller screws in the kit. Just be careful not to drop the hub as it comes out of the housing. Edited December 19, 2008 by hohieu corrected typo Link to comment Share on other sites More sharing options...
unibrook Posted December 19, 2008 Author Share Posted December 19, 2008 Perfect, thanks Hohieu. Any way I can contact you offlist if I have further questions specific to this task? thx, nwlovell at yahoo.com Link to comment Share on other sites More sharing options...
hohieu Posted December 19, 2008 Share Posted December 19, 2008 I just responded to your PM -- a bit sonner this time around. Last time, I think it took me over a year to sent you the specs for testing the ignition coil . I was out of the country during most of that time, but even when I'm online, I often don't notice that I have a PM unless you give a heads up. Link to comment Share on other sites More sharing options...
