wallaby Posted December 18, 2008 Share Posted December 18, 2008 have done a few seaches but cant seem to find any info. the odometer in my 01/82 Brat(DL?) is not working - speedo works just fine but the odo dosen't . I'll admit this is not a life threatening situation but it is annoying - i like to know my fuel milage and i sometimes use my car for work and get paid for milage. i have a parts car - also an 82(DL wagon) that had the same instrument cluster so I changed it out (it has less miles on it:) ) but it has exzactly the same problem:-\ ) next i decided to investigate more closely and found the little gears that drive are not meshing like they should. Is this a common problem? this is also a std dash - only temp and fuel no tach so i don't see much point in trying to fix it. can i install one with full instruments(temp,oil,battery,fuel & tach)? will it use the same wiring? is there wiring there and i just need to get sending units? would it be easier to fix or replace and install aftermarket tach etc? if there is something i can replace it with - then does any body have one? Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted December 18, 2008 Share Posted December 18, 2008 Something may have popped loose inside your instrument display for your odometer. I believe it is gear driven off of the speedo shaft. You may be better off replacing your dash piece. Link to comment Share on other sites More sharing options...
wallaby Posted December 18, 2008 Author Share Posted December 18, 2008 (edited) as mentioned can i replace it with one with a tach it it? Edited December 23, 2008 by wallaby felt like it Link to comment Share on other sites More sharing options...
wallaby Posted December 23, 2008 Author Share Posted December 23, 2008 i guess no one has experience with this next question... what year range has simmilar instruments to my 82? Link to comment Share on other sites More sharing options...
