[HTi]Johnson Posted December 20, 2008 Share Posted December 20, 2008 Hello all. It's been ages since I posted in the general forums. The story: The other day, I finally got to take my 1988 DL Wagon, with it's untested 4 inch lift out to play. It did awesome. There was some steep road climbs with snow that it just pushed on through. THEN....I found a trail that no one has used. My friend walked along the trail and scouted it out. He said that there was a little puddle in part of it, so I went for it, I had to cross some deep ruts to continue on with the trail and about 50 yards into the trail...it felt like my front end just got ripped out. What it turned out to be was the fact that the "little frozen puddle" was a 3 ft deep puddle with 2 inch thick ice over it. My car actually made it a car length and a half onto the ice before it fell through. The questions: So, the car was at operating temp before taking the ice bath, what could that do to the engine (it was never completely submerged.)? I turned the car immediately, so I know I didn't hydro lock it. But could a starter cause hydrolock damage? When I got it home, had to be towed, I drained the oil and front diff. Oil was a milkshake and the diff was normal. Thanks for your time, [HTi]Johnson Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted December 20, 2008 Share Posted December 20, 2008 My suggestion would be to take each spark plug out, and rotate the engine by hand. Then put the plugs back in, if you have some oil from a previous oil change, throw that in there, and start the engine (if it can). Let her run for about 15 mins. Drain the oil, and put fresh in. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted December 20, 2008 Author Share Posted December 20, 2008 I did the spark plug thing. It sounds like it's running on 2 cylinders. I think the disty may have water in it. It's also spfi. Link to comment Share on other sites More sharing options...
subiemech85 Posted December 21, 2008 Share Posted December 21, 2008 Johnson;777719']I did the spark plug thing. It sounds like it's running on 2 cylinders. I think the disty may have water in it. It's also spfi. they sound very good when running on 2 cyl ea81 only 1 and 2 were working 4 was off it's rocker 2 bent pushtube only front cyl's worked, but very smooth and quiet since you did not say which engine , it could also be that # 1 / 3 timing belt is off Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted December 21, 2008 Author Share Posted December 21, 2008 It's an ea82. Come to think of it, I haven't check the right timing belt. I checked the left one just to make sure the disty was still spinning. Link to comment Share on other sites More sharing options...
The Scooby Posted December 21, 2008 Share Posted December 21, 2008 easy way to get water out of a cylinder. pull the plugs and fill the cylinder with rubbing alcohol, it will stay at the bottom and push up the water, then it will evaporate and your good to go. Link to comment Share on other sites More sharing options...
Quidam Posted December 21, 2008 Share Posted December 21, 2008 FYI. Water and my Justy. I went through a creek, twice. Justy got wet. A foot of water? I don't know, I was having fun. Pulled the carpet. One belly plug was out of the socket. No wonder. Two plugs in back were loose. I put the plugs back in. ripped out the carpet and padding. Not looking back on this one. Sincerely, Quidam P.S. I got the electronics "wet" under hood, in the car, codes all over the place. Tranny, engine, so on and so forth. I tried to dry it out. Air under compression, etc. We'll see. Doug Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted December 22, 2008 Author Share Posted December 22, 2008 So...turns out the timing belt tensioner on the left side of the engine came loose and through off all the timing. It runs like a champ now. Link to comment Share on other sites More sharing options...
