Durania Posted December 22, 2008 Share Posted December 22, 2008 (edited) So its 5 degrees here this morning and I go out to start my RS and the thing barely will turn over, it starts finally but not like it wants to. Is this the sign of a weak/cheap battery? What do you guys do about our doors getting froze to where they won't open? I had to go in passenger side and tore the bottom weather stripping off in the process and had to pop it back in. Any advice? I need it. Edited December 22, 2008 by Durania Quote Link to comment Share on other sites More sharing options...
Bucky92 Posted December 22, 2008 Share Posted December 22, 2008 How old is the battery in it?? My 08 will do the same thing though if its really cold...thinking on going with a redtop to see if that fixes the problem. As for the door weather stripping..I used to use spray silicone every couple weeks on my Loyale Quote Link to comment Share on other sites More sharing options...
subsince77 Posted December 22, 2008 Share Posted December 22, 2008 What weight oil are you running? I use 5/30 all year, which is what the manual calls for anyway. I use an oil pan heater at 0 and below, but I have started the car at -25 without the heater. It turned over a little slow, but started fine. The heater makes a huge difference. How many mornings do you get at 5 degrees in Tennessee? Might not be worth doing too much other than a good battery and good oil, which are both nice to have anyway. The door freeze on Subarus is a big pain. I fight it all the time. Many here say silicon, that has never helped me much. I had to re-glue all my weather-stripping last year. I have had to crawl in from whatever door I could open a number of times. I'd like to find a good solution to that myself. Luckily, once it gets really cold out, staying below zero a lot, it never melts enough to get the door wet, so it doesn't start freezing again until early spring. Quote Link to comment Share on other sites More sharing options...
Durania Posted December 22, 2008 Author Share Posted December 22, 2008 I had my oil change done at the dealership along with a coolant change last month. I am unaware as to what viscosity of oil they put in it but I am confident it was the recommended type. I will use your idea about the silicone spray. I think what happened is it rained all last week then got cold all of a sudden and I had some water in my door jamb and gave it a place to freeze to. In Tennessee we do very rarely get temperatures like what we experienced this morning. Not really worth the price of buying a heater over in my thoughts. Quote Link to comment Share on other sites More sharing options...
dhise Posted December 22, 2008 Share Posted December 22, 2008 Last January my loyale would barely crank over when it was near 0F and the battery lasted all summer afterwards until it finally died. You probably have a little time to replace it before it craps out. If you let the car sit for more than a week w/o charging I bet it'll die for sure then. Quote Link to comment Share on other sites More sharing options...
Durania Posted December 22, 2008 Author Share Posted December 22, 2008 It had just been a weekend since I last started the old girl. Thanks for the tips people. Quote Link to comment Share on other sites More sharing options...
dave1rr Posted December 23, 2008 Share Posted December 23, 2008 For the door seal problem, try 303 Aerospace Protectant. http://www.303products.com/ I use to use silicone ( it should be 100% pure silicone) but now use the 303 a couple of times a year. Quote Link to comment Share on other sites More sharing options...
forester2002s Posted December 23, 2008 Share Posted December 23, 2008 I use a solid silicone white stick (or is: solid white silicone stick?). I wipe it on directly to the DRY and CLEAN rubber door-seal, and then go over the surface very gently with a clean paper-towel. I do this once a year before the winter - it's never let me down. Quote Link to comment Share on other sites More sharing options...
subsince77 Posted December 23, 2008 Share Posted December 23, 2008 I use a solid silicone white stick (or is: solid white silicone stick?). I wipe it on directly to the DRY and CLEAN rubber door-seal, and then go over the surface very gently with a clean paper-towel. I do this once a year before the winter - it's never let me down. Where do you get that? I've just used spray. Quote Link to comment Share on other sites More sharing options...
screwbaru2 Posted December 23, 2008 Share Posted December 23, 2008 Try turn your headlights on for a minute before starting. This gets the battery "warm" without putting a big load on it. I throw hot water on my door then spray it down with WD 40 after I open it to displace the water. shut the lights off before starting. Quote Link to comment Share on other sites More sharing options...
forester2002s Posted December 23, 2008 Share Posted December 23, 2008 Where do you get that? I've just used spray. I can't recall where I bought my silicone stick (they last a long time). Try a hardware store, or auto-parts store. Quote Link to comment Share on other sites More sharing options...
