bicycle_ben Posted December 29, 2008 Author Share Posted December 29, 2008 (edited) ok so what do i actually have to do to get the old axle out? you can see the threads on the end of the fresh axle so im guessing there is a nut in there somewhere holding the old one on... i thought i could get to the nut by taking off the stuff you see in the picture but sadly i am mistaken if i pull the brakes off the rotor will the rotor slide off the splines and expose the nut i want ? Edited December 29, 2008 by bicycle_ben Link to comment Share on other sites More sharing options...
s'ko Posted December 29, 2008 Share Posted December 29, 2008 WHAT HE SAID.... (if I remember correctly from the pictures, the axle was already pulled apart at the tranny. With the castle nut removed, you just need some persuasion to get the axle out. I 2X4 w/a hammer works nicely. If you are not planning on using the axle again, just hammer it directly. It's easier to get the axle back in by removing the ball joint.) BW Link to comment Share on other sites More sharing options...
bicycle_ben Posted December 29, 2008 Author Share Posted December 29, 2008 Also are you sure that's the right axle? It looks a little long in the picture. What did it come off of? dang youre good! yeah its not the right one -guess thats what you get when you grab one out of a pile at your friends house i got the old one out now, just had to pound harder on it than i thought i should Link to comment Share on other sites More sharing options...
bicycle_ben Posted December 29, 2008 Author Share Posted December 29, 2008 the other one is quite a bit different once you have them side by side i need to get one of those plastic keyboard covers so i dont have to wipe off my hands every time i run upstairs to post something! Link to comment Share on other sites More sharing options...
Davalos Posted December 30, 2008 Share Posted December 30, 2008 Wow - I'm just now catching up on this thread ... what an adventure! Keep the pics coming. Link to comment Share on other sites More sharing options...
bicycle_ben Posted December 30, 2008 Author Share Posted December 30, 2008 so i had to tap the old axle out with a hammer - how do you get a new one back in? there really isnt a good way to tap on the back of it unless you take the boot off, pull the CV joint a part and then hit the back of the cup with something ... and does anyone know if an 86 wagon axle will fit an 81? they are not exactly the same but look close enough it might work. Link to comment Share on other sites More sharing options...
bratman18 Posted December 30, 2008 Share Posted December 30, 2008 so i had to tap the old axle out with a hammer - how do you get a new one back in? there really isnt a good way to tap on the back of it unless you take the boot off, pull the CV joint a part and then hit the back of the cup with something ... and does anyone know if an 86 wagon axle will fit an 81? they are not exactly the same but look close enough it might work. The axle will only fit if it's the same body style car...which is EA81. If it has the same front end as your car then it will fit, if it looks like a Loyale then it won't. To get the new axle in make sure you take some sandpaper and take of any corrosion on the end of the axle where it slides through the hub. Then what I do is use a home made slide hammer, But I think if you prep it good enough it will slide in. then once you can get the hub back on you can use the axle nut to tighten it into place. Good luck! Link to comment Share on other sites More sharing options...
zyewdall Posted December 31, 2008 Share Posted December 31, 2008 and does anyone know if an 86 wagon axle will fit an 81? they are not exactly the same but look close enough it might work. Probably not -- the '86 wagon is the EA82, wherease the '81 is the EA81. The '86 hatch is the EA81... but not the wagon. I think the EA82 is a little longer? Z Link to comment Share on other sites More sharing options...
bratman18 Posted December 31, 2008 Share Posted December 31, 2008 Probably not -- the '86 wagon is the EA82, wherease the '81 is the EA81. The '86 hatch is the EA81... but not the wagon. I think the EA82 is a little longer? Z Yes the axle on an EA82 is longer but he may be referring to the 86 wagon and meaning that it is an EA81 so he needs to clarify the body style Link to comment Share on other sites More sharing options...
bicycle_ben Posted December 31, 2008 Author Share Posted December 31, 2008 the donor car in question is a 5 door wagon style body. im fairly sure i remember seeing EA82 stamped on the engine which means it cant donate an axle to my car ill have to call the U pull in town and see if i can find some other old subies there Link to comment Share on other sites More sharing options...
bratman18 Posted December 31, 2008 Share Posted December 31, 2008 the donor car in question is a 5 door wagon style body. im fairly sure i remember seeing EA82 stamped on the engine which means it cant donate an axle to my car ill have to call the U pull in town and see if i can find some other old subies there Yeah if it doesn't have the same "curves" as your car then it won't fit. Yours is EA81 and it has to come from another EA81. Good luck!!! Think of all the good stuff you're learning!! Link to comment Share on other sites More sharing options...
bicycle_ben Posted January 3, 2009 Author Share Posted January 3, 2009 (edited) got a rebuilt axle from Schucks today, popped that baby in there, only took me 20 min thanks for all your help guys! now i have a car again and i can go snowboarding! Edited January 3, 2009 by bicycle_ben Link to comment Share on other sites More sharing options...
bicycle_ben Posted January 4, 2009 Author Share Posted January 4, 2009 180ft/lbs aught to do it. i backed it out of the garage and moved it into the car port on its own power. i didnt notice anything that felt bad but i think i aught to get it aligned just to be sure Link to comment Share on other sites More sharing options...
