Suberstar88 Posted December 25, 2008 Share Posted December 25, 2008 So i get most the bolts off my passenger side fender to take a look at the snorkle, but theres two damn bolts right behind the light that no tool i own can get to and get leverage on!! Do i really have to take the front bumper off too? Link to comment Share on other sites More sharing options...
opus Posted December 25, 2008 Share Posted December 25, 2008 It can be a bugger, but you can do it with a ratchet. I did a few and had to do a little prying, or have someone stand on the bumper. If not, a wrench will work. Amazing little buggers at times. Link to comment Share on other sites More sharing options...
Suberstar88 Posted December 26, 2008 Author Share Posted December 26, 2008 Yea,ill take a longer look at it, it's cold as hell outside so i didnt want to play around with it too much=) Link to comment Share on other sites More sharing options...
DaveT Posted December 26, 2008 Share Posted December 26, 2008 I always removed the bumper. 4) 14mm bolts, 2 signal lamp plugs. I make adjustments in the position of harness & hoses that are sometimes in the way of the bolts so if there is a next time, it is easier. Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 26, 2008 Share Posted December 26, 2008 +1 for removing the bumper. It seems like it would take more time but in reality, its easier and faster to remove the 2 14mm bolts with a ratcheting wrench and them remove the 2 10mm bolts on the fender with an air ratchet or regular ratchet instead of trying to monkey f*** around with it;) Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 26, 2008 Share Posted December 26, 2008 Yes, remove the Bumper, but I Suggest to use some Penetrating Oil there, `cos bolts can be Rusted and Hard to Turn... Good Luck! Link to comment Share on other sites More sharing options...
Suberstar88 Posted December 27, 2008 Author Share Posted December 27, 2008 How much of a difference does this mod make? Link to comment Share on other sites More sharing options...
EvilDead Posted December 27, 2008 Share Posted December 27, 2008 It's a EA series engine, so not much, if any. Link to comment Share on other sites More sharing options...
