offroadsubie1 Posted December 26, 2008 Share Posted December 26, 2008 These are the only wires on my car that i dont know what go to and i want to get it running while the snow is still on the ground. Link to comment Share on other sites More sharing options...
bratman18 Posted December 26, 2008 Share Posted December 26, 2008 (edited) I think that they go to the coil, not positive though Edited December 29, 2008 by bratman18 Link to comment Share on other sites More sharing options...
bicycle_ben Posted December 26, 2008 Share Posted December 26, 2008 i have several wires and plugs that dead end or are not connected but the car still runs ... maybe i should just rip those wires out... now some of the wires that dead end are supposed to run my rear defroster and wiper motor... and who knows what else, maybe i shouldnt rip them out... Link to comment Share on other sites More sharing options...
92loyale Posted December 26, 2008 Share Posted December 26, 2008 Looks like Coil wires to me as well. Positive negative and RPM pickup. I could be wrong but, sure looks like it to me. Link to comment Share on other sites More sharing options...
offroadsubie1 Posted December 26, 2008 Author Share Posted December 26, 2008 Where do they connect to the coil at? Link to comment Share on other sites More sharing options...
bratman18 Posted December 26, 2008 Share Posted December 26, 2008 Where do they connect to the coil at? There should be two posts on the coil itself and then somewhere in the same area there will be a little black plug for the other one to plug into. Link to comment Share on other sites More sharing options...
offroadsubie1 Posted December 26, 2008 Author Share Posted December 26, 2008 By posts do you mean where it bolts onto the car? i am doing a motor swap and i still have the old coil from the 1.8l carbed motor and i put a 1.8l turbo fuel injected motor in it, are the coils the same or am i going to have to buy a new coil? Link to comment Share on other sites More sharing options...
Phizinza Posted December 29, 2008 Share Posted December 29, 2008 The black n red one is probably the resistor bypass wire. It is made to give the engine full battery volts while starting. This is because the starter drops the volts very low and then the resistor on the coil drops it again so you end up trying to start on 8 to 9 volts on a 10v coil. The plug one looks like it should plug into the fuseable links box. And the black n yellow should go on the negative side of the coil. Link to comment Share on other sites More sharing options...
offroadsubie1 Posted December 31, 2008 Author Share Posted December 31, 2008 So does the red and black one go to the coil? And what is the fuseable links box? and where is it? Link to comment Share on other sites More sharing options...
Durania Posted December 31, 2008 Share Posted December 31, 2008 So does the red and black one go to the coil? And what is the fuseable links box? and where is it? It is located right under where the coil would go. It should have a gray cover of it red and green wrote on the top of it. If you pull the cover off, you will have three wires inside of it. Those are your fusible links. Link to comment Share on other sites More sharing options...
offroadsubie1 Posted December 31, 2008 Author Share Posted December 31, 2008 The plug thing doesnt plug into it though, i dont know where it goes or if i need it Link to comment Share on other sites More sharing options...
Phizinza Posted December 31, 2008 Share Posted December 31, 2008 What model/age is the car and what colour are all the wires you have there... I can look it up in my manual wiring diagram if you want. Link to comment Share on other sites More sharing options...
offroadsubie1 Posted December 31, 2008 Author Share Posted December 31, 2008 I think it is an 88 but i am not 100% sure of that and it is the 1.8l turbo motorm not sure what kind of car it is out of, i am doing a motor swap. Here are the wires i dont know where they go, and also that plug i dont know where it goes? it looks like i am missing something down there but i dont know what it would be. The bottom picture is where the wires are, they are right by the coil Link to comment Share on other sites More sharing options...
bratman18 Posted December 31, 2008 Share Posted December 31, 2008 Do you have any wires attached to the coil? Link to comment Share on other sites More sharing options...
offroadsubie1 Posted December 31, 2008 Author Share Posted December 31, 2008 Yeah i have wires attached to the coil, my car will turn over, but it doesnt have any spark. Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted December 31, 2008 Share Posted December 31, 2008 put a multimeter on those wires, one at a time with the ignition in run to see where the juice for the coil is. Link to comment Share on other sites More sharing options...
