painting block
Paint does not stick to aluminum well but it can be painted Ive seen lotsa trannys' painted but they usually end up looking worse than if they had not been painted. Also aluminum isnt usually painted because it doesnt rust like cast iron. (why waste the money)
  Jerry DeMoss said:
Quite a few of the aircraft guys with subie swaps powder coat their blocks. I don't see any reason not to paint it with your favorite high temp paint.
Except for the most part where they fly tend to be a lot colder then surface temps.
I've seen painted corvair blocks, vegas, and VW blocks. Engines used to be apinted to protect them from rust. Its not really needed on aluminum engines.
nipper
