Announcements
Yet another LB the coupe update:
  • Replies 60
  • Created
  • Last Reply
Top Posters In This Topic
Congrats!!!! At least you found the problem. Should be all good now!
Far from good actually..have to replace the motor...and then the tranny needs replaced too sometime in the future.. Grrrrr
We sent the pics to Tom at AWD.inc and he said ..Nope ..garbage..probably caused by oil starvation..I have a new oil pump on it I need to inspect..and the marks were not there when I originally tore it apart
Edited by Bucky92
Yeah but at least you know some of the problem now and with a new temp gauge and now that you know the fan will work, you shouldn't have to worry about any more hang ups!! So at least you're making progress!
New motor is officially in the garage...need to strip parts from the old one to put in the new one..clean it and make it all pretty...and our goal is to be dropping it into the coupe on the weekend of the 24th. Keep your fingers crossed. If this doesnt work ..we are just going to say..screw it..EJ22.
Do you think guys think I should order new valve cover and oil pan gaskets for the new motor.??.I want to swap mine from the old motor over ( slightly better shape) thing is...both motors have a fresh reseal so all gaskets are new.
Arent valve cover gaskets like 10 bucks for the pair? for that much I would just get new ones, coat them in RTV and let them sit, then install those. And if you cant get them that cheap, I have a a pair for that cheap.
-Bill
You are correct. I bought fel-pros for my BRAT and they were $8.99.
