81 brat shocks
Remember, you can use ANY strut assembly from a Subaru 77-79 2wd or 4wd. The only difference is the height adjustment, so that drives a different and longer cartridge for the 4WDs.
If you use a 2WD strut assembly, you lose the height adjustment and the front is just normal height. (No biggy) The front strut cartridges are easier to find for the 2WDs.
Todd
  • 4 weeks later...
Got shocks for the rear, which has sorted the ride a lot.
Think they're from a corolla of similar vintage.
The oe shocks aren't made anymore, but the important things to know are the mounts:
Bottom: 16mm eye (actually around 25mm with 16mm bushes)
Top: 10mm stud
and the length:
Compressed - 345mm max
Extended - 405mm min
