windshield wiper motor
I changed out the wiper motor on my old BRAT a year before I sold it. It is a real PITA. First you need to take the cowl cover off and inside you will see the output part of the wiper motor. The subaru factory service manual says to fabricate a tool so you can push the plastic tabs inward on the wiper control arms. Best I could do was two sets of needle nose pliers, don't pinch the piss out of yourself like I did. Some people have used sockets to do this. The wiper motor is held onto the firewall by three 10mm bolts if memory serves me correct
or do what I did
remove motor
remove flat cover over gearbox
remove round cover over motor
clean and lube motor and gearbox
reassemble
reinstall
ADD ground wire from gearbox cover screw to strut tower or other suitable ground point
So you noticed a big difference?
you may be able to remove motor without removing cowl plate!
let us know how it turns out
yeah the whole motor is right under the hood, so I'm gonna take it apart when I get the chance and clean it etc. Thanks again and I will post my results!
On my Hatch, I lost intermittent wipers, and just had slow cycling on all settings. Turned out, the little contact wipers that ride the gear under the cover were bent and shorted. Fixed that, put a little more grease in there under the cover, and it worked great the rest of the time the car lived.
  • 8 years later...
