ericem Posted December 28, 2008 Share Posted December 28, 2008 (edited) Hello! Today was driving off and going about honking the horn to say fairwell. Then I noticed. My damn horn doesn't work! Checked all the fuses there all good. Can't really hear a click? I am thinking a bad relay. So where would I find this rellay? I read a few threads some said near the firewall (that doesn't help many relays are near the firewall hehe), another individual said something about a fuse box that needs to be removed then it is behind there? A red relay supposedly? Now my day runner issue, I doubt it is related to my horn issue but you never know i guess? Anyway, before when I would put the car in D or R w/e with the lights in the off position they would turn on the headlights, now nothing, did not really realised the issue till my dad pointed it out. Now if I turn on my headlights normally on low beam they work, as well as high beams work. All lights seem to work just fine, just wondering what is up with the day runners? I did replace the bulbs with silverstars. Not sure if that is my problem? Tomorrow I am going to try my original bulbs and see if my day runners work and run a ground to the horn mount. Just want to know where the relay is for the horn mainly! Thanks guys. Edited December 28, 2008 by ericem Link to comment Share on other sites More sharing options...
nipper Posted December 28, 2008 Share Posted December 28, 2008 so we are going to have the guess the year of this car? hrmmmmmmmmm Link to comment Share on other sites More sharing options...
ericem Posted December 28, 2008 Author Share Posted December 28, 2008 Crap it is in my profile forgot I don't have a signature. I deeply apologize nippy It is a 1993 Subaru Legacy Wagon L with a 2.2L non turbo (Engine code EJ22E). Link to comment Share on other sites More sharing options...
nipper Posted December 28, 2008 Share Posted December 28, 2008 HOrn is probably as simple as a dead horn. The car is old enough. Daytime runing lights can be the jhand brake switch. nipper Link to comment Share on other sites More sharing options...
ericem Posted December 28, 2008 Author Share Posted December 28, 2008 Thanks for your reply. Ok well the horn I guess I will have to finalize tomorrow. Just like I said, I do not hear any clicks. Also if the hand brake switch is bad, the light would be on the dash wouldn't it? If I pull the handbrake I do see the red light come on, then if i lower it light turns off. Isn't it running of the same switch? Link to comment Share on other sites More sharing options...
ericem Posted December 29, 2008 Author Share Posted December 29, 2008 OK, well the relay is indeed behind the fuse box, the one on the A pillar I believe it is called. Got it out stuck my hand in between there after I removed two nuts. The contacts were very corododed and if I hit the relay manually with a screw driver, the horn sounds. So going to order a relay. Now I need to work on the day runner issue, it is more of a safety concern for me. Link to comment Share on other sites More sharing options...
johnceggleston Posted December 29, 2008 Share Posted December 29, 2008 maybe you shouyld try and identify the dayrunner relay, it too could be corroded. or just check them all one at a time. Link to comment Share on other sites More sharing options...
ericem Posted December 29, 2008 Author Share Posted December 29, 2008 Going to do a search. Anyone know where the day runner relay is anyway? Link to comment Share on other sites More sharing options...
nipper Posted December 29, 2008 Share Posted December 29, 2008 From what i remember its on the passenger sidebetween the glovebox and the body. nipper Link to comment Share on other sites More sharing options...
ericem Posted December 30, 2008 Author Share Posted December 30, 2008 Hmm, I was messing around with the heater motor and removed the glove box. Going to take a look thanks! Link to comment Share on other sites More sharing options...
nipper Posted December 30, 2008 Share Posted December 30, 2008 Well thats where the Haynes manual says it is Link to comment Share on other sites More sharing options...
ericem Posted December 30, 2008 Author Share Posted December 30, 2008 New horn relay is in, and the horn is up any running again Next up, get someone to shift to D while I am listening for a click on the passenger side. Makes me think though, if the horn relay looks the way it does. How does my fuel pump relay look per say? Or is it a much more reliable relay? Link to comment Share on other sites More sharing options...
ericem Posted January 2, 2009 Author Share Posted January 2, 2009 Found the culprit was hitting relays and realized the lights started flickering. So I found this relay and it was filled with water and when you shake it everything was loose. (was not mounted on the mount was on the floor so it got wet) anyway so I am trying to find the part number. Typed in the one on the top of the relay on Subaru Genuine with no luck going to call the dealership. Link to comment Share on other sites More sharing options...
johnceggleston Posted January 2, 2009 Share Posted January 2, 2009 Search by OEM Part Number: (Select Make) Subaru Multi-Part Search OEM Catalog Item Number ............. MSRP......... Core Price ............. Price 84057aa000 ............................... $125.88 ........ $0.00 ............... $90.64 RESISTOR Link to comment Share on other sites More sharing options...
Gloyale Posted January 2, 2009 Share Posted January 2, 2009 johnceggleston said: Search by OEM Part Number: (Select Make) Subaru Multi-Part Search OEM Catalog Item Number ............. MSRP......... Core Price ............. Price 84057aa000 ............................... $125.88 ........ $0.00 ............... $90.64 RESISTOR Junkyard part FTW! Link to comment Share on other sites More sharing options...
johnceggleston Posted January 2, 2009 Share Posted January 2, 2009 Gloyale said: Junkyard part FTW! absolutely Link to comment Share on other sites More sharing options...
ericem Posted January 2, 2009 Author Share Posted January 2, 2009 Indeed! Funny the dealer locally said $68. Cheaper than online, now thats a first. Link to comment Share on other sites More sharing options...
nipper Posted January 2, 2009 Share Posted January 2, 2009 Why not drive with the headlights always on? nipper Link to comment Share on other sites More sharing options...
ericem Posted January 2, 2009 Author Share Posted January 2, 2009 Then my interior lights run! Annoys the crap out of me lol. Particularly because the radio will dim when the headlights are on. Link to comment Share on other sites More sharing options...
