4eat to 5speed AWD D/R Swap
Hello all.
I'm going to be putting a 5speed in my RX and just want to know what all do I need from the donor car to make the diff lock switch work?
Is there a way to make it work without chasing the wiring harness under the seats and behind the dash?
Thanks for your input.
-Justin.
You can just make a harness yourself so its totally exposed (ie its own harness instead of integrated into the rest of it). Thats what my plans were. You'll need the basic stuff from the donor car for any auto -> manual swap but you'll also need the vacuum solenoids, switch, and the vacuum lines and connectors. Its a fairly easy wiring harness to make.
