wtdash Posted December 30, 2008 Share Posted December 30, 2008 I'm putting a set of stock heads on an EJ22T that have been 're-surfaced' per the original owner, but don't know if the rocker assemblies were removed to do this. If they were I probably need to bleed the HLA's, correct? Is there anyway to tell if they need bled? According to the FSM, it looks to be a PITA. Thanks! Link to comment Share on other sites More sharing options...
Gloyale Posted December 30, 2008 Share Posted December 30, 2008 I'd do them on principal. You'll have way lower chances of ticking. You'll likely find little specs of debris in a few of their inlets. Pulling them out of the rocker is the hardest part, but doable. Carefully grabbing the shoulder with a pair of Vise Grips works pretty good. At least these don't take a 2inch deep pan of oil like EA hydros. Link to comment Share on other sites More sharing options...
