Deener Posted December 31, 2008 Share Posted December 31, 2008 Hello All, I would firstly like to thank all of you for answering some of my issues in the past. You have helped me through some tough issues and your advice is invaluable to me. I have an 88 GL Wagon 4x4 and I want to keep it going as long as I can. This is my first Subaru and also my first 4 wheel drive. I am just wondering if there is anything outside of standard tune up/maintenance procedures that I should be aware of to keep my car sliding effortlessly through the snow, sideways, uphill, as I pass all the people with their jaws on their laps? I am not an idiot driver, I am just remarking on how much control is available in the slippy stuff. Heres what I have done so far: Plugs Dist Cap (rotor was good) Oil/Filter Air Filter Front Brakes (debating about swapping the back shoes for discs) Battery Alternator CV Axles (front) Thermostat/Flush Any suggestions are appreciated. Cheers, Dean Link to comment Share on other sites More sharing options...
Gloyale Posted December 31, 2008 Share Posted December 31, 2008 Heres what I have done so far: Plugs Dist Cap (rotor was good) Oil/Filter Air Filter Front Brakes (debating about swapping the back shoes for discs) Battery Alternator CV Axles (front) Thermostat/Flush Why would you try to save 5 dollars here? replace the rotor too. Also replace the fuel filter. I hope as well you used a genuine Subaru Thermostat. I would replace whatever you put in with a genuine one or you risk overheating. Link to comment Share on other sites More sharing options...
Deener Posted December 31, 2008 Author Share Posted December 31, 2008 That was a fast reply. Yes, I did the fuel filter...I just forgot to mention it. I have read a bit on this site about using OEM T-stats. I honestly don't know what type I bought, as I got it from a small local dealer here in Vancouver (Vancouver Auto Parts). I had him confirm the open/close values for me that I found in my Haynes manual. You are right, I should have got a rotor as well. I wasn't trying to save 5 bucks....I am just an aspiring backyard mechanic. I just took advice from someone that I shouldn't have about the rotor. Link to comment Share on other sites More sharing options...
Skip Posted December 31, 2008 Share Posted December 31, 2008 I am just an aspiring backyard mechanic. I just took advice from someone that I shouldn't have about the rotor. Then please also do as Gloyale says and get an OEM thermostat. No transmission is mentioned but if it's automatic a fluid flush ia also a good idea. Link to comment Share on other sites More sharing options...
Skip Posted December 31, 2008 Share Posted December 31, 2008 One more thing about the rotor If this is an SPFI EA82. the rotor is held on my a small screw, blue loctite is a good idea when replacing it. Link to comment Share on other sites More sharing options...
Deener Posted December 31, 2008 Author Share Posted December 31, 2008 Thanks Skip. Yes, It's an automatic, with the best red button on the stick that was ever invented. (on demand 4 wheel) I'll do a search on how to do the tranny fluid flush. I would assume there's a some kind of plug. I think it is an SPFI. I honestly don't know how to tell the difference between EA81 and EA82. Is there an easy way? I think mine is an EA82. Most of the same car years/models I see here list that as their engine type. As far as acquiring OEM parts goes...is there a Vancouver BC favorite shop or do I have to bow to the dealer? Link to comment Share on other sites More sharing options...
zyewdall Posted December 31, 2008 Share Posted December 31, 2008 In the north american market, the '88 wagons were all SPFI EA82's, I believe. Overseas, there was more variation. Z Link to comment Share on other sites More sharing options...
The Dude Abides Posted December 31, 2008 Share Posted December 31, 2008 What type of plugs did you use. They recomend NGK for plugs and wires. Sounds like you did lots of the stuff already. Rear disc parts arent hard to find but proball cost you just 100 in parts alone. Link to comment Share on other sites More sharing options...
Deener Posted January 30, 2009 Author Share Posted January 30, 2009 What type of plugs did you use. They recomend NGK for plugs and wires. Sounds like you did lots of the stuff already. Rear disc parts arent hard to find but proball cost you just 100 in parts alone. I can't remember what plug types they were. I think Bosch actually if I remember the package correctly. NAPA up here has some brake shoes for 50 bucks for a full set. I am in the middle of attempting my first wheel bearing job and I am noticing too much wear on the shoes so they will get replaced first, conversions at a later date. BTW - with a disc conversion like that do you not have to balance the pressure distribution somehow or does it do it on its own? Link to comment Share on other sites More sharing options...
