Lights on stock bumper?
The KC HiLighters are mounted to aluminum plates
I fabricated to replace the turn signal housings
The turn signals are rewired to the white side lights
beside the head lights.
Makes it a bit safer as the turn signals can now been seen from
the side better than before.
just add more length to both original wires. like 3 foot more each side for side lights and 3 foot more for bumper signals...route wiring in vice - verca location from factory, install driving or foglights in bumper, and hook up lights.
Sweeet, doesnt sound hard to do right:banana:
Actually Mr. Bhien makes it more difficult than it really is.
Follow the wiring from the turn signal and you will find it up by
the parking light that I converted to a turn signal.
It was a simple splice at that point, no "3 foot of wire" needed.
I also changed the lamp to an amber colored one, and left
the small corner marker as the "parking light"
On my wagon, there were factory pre-drilled holes already in the metal reinforcement on the underside the bumper. I just crawled under the car, drilled through the plastic and was good to go. The cool thing was, I didn't have to measure to make sure the lights were evenly spaced.
anyone ever try putting them on the bottom side of the bumper. I know the 6 inch round ones woudl work but how about some 4x6 lights.
Ben
Ea82 had factory driving lights that were mounted on the bottom. There is a metal strip that is screwed on the bottom and they just bolted up to that.
I have lights under the bumper, I didn't take into account busting through snow drifts - so I broke a lens two nights back, could have been gravel in the plowed snow berm or the shock of rapid cooling, dunno
when it isn't the end-of-the-world-weather I will be moving them to the top of the bumper, I wish I could come up with a roof mount that didn't look cheesy
btw, throwing the extra wide light to the sides has definitely kept me from having a zillion rude deer surprises and helped me to figure out where the road center was in really really bad weather
