Bucky92 Posted January 14, 2009 Share Posted January 14, 2009 You can decode the car yourself ..do a search there is a step by step in the repair manual section and what the codes are Quote Link to comment Share on other sites More sharing options...
vincentmoy Posted January 14, 2009 Author Share Posted January 14, 2009 You can decode the car yourself ..do a search there is a step by step in the repair manual section and what the codes are Thank you for the info. I have looked @ that post (assume the one I read is the one you are talking about). The only problem is I don't know where the module is. I have looked under the hood and there is nothing looks like a module with LED light on it. Vincent Quote Link to comment Share on other sites More sharing options...
Skip Posted January 14, 2009 Share Posted January 14, 2009 Sir Vincent, The ECU which has the LED you seek, is under the dash, to the left of the steering col. Remove the panel that is above your knees when driving and look up. If the Check Engine light is on, the flashes will be present as soon as you turn the key to "Run" Do not start the car. Quote Link to comment Share on other sites More sharing options...
vincentmoy Posted January 14, 2009 Author Share Posted January 14, 2009 Sir Vincent,The ECU which has the LED you seek, is under the dash, to the left of the steering col. Remove the panel that is above your knees when driving and look up. If the Check Engine light is on, the flashes will be present as soon as you turn the key to "Run" Do not start the car. Thank you thank you thank you!! I will do that hopefully this weekend. Now I'm enjoying my "new" 98 Impreza obs:banana::banana: Quote Link to comment Share on other sites More sharing options...
