Subaru RX Problems
Hi !
I'm from Sweden so excuse my bad english :)
I have an Subaru RX Special -88
with the EA82T Engine.
I got this car from my cousin after he got some
problems with it.
The problem was that one of the timingbelts was broken.
Now after i replaced them and got the car running.
I was driving it home from the garage when i had driven
for 30km and then after a speedbump, when i was accelerating
it suddenly died.
I couldent get it to start again.
When i came home with the car 1 hour later it started again.
Now to the problem.
The car will start and run good on idle speed.
But when i'm drivin i can drive for about 20 meters before it dies and
will not start again for some time.
After some time it will start again and the same problem will accour.
Please help me :)
I want to drive it in the snow :D
Best regards from Sweden !
It would be good to know if the problem is fuel or spark when the engine dies. You can pull a plug wire and use an extra spark plug to see if there is spark. I would not recommend testing for spark without a spark plug as the ignition coil can be damaged.
My guess is that something in the ignition system is failing, or possibly something loose. The ignition coils can have problems; I replaced mine with a MSD #8222 and I also installed nice MSD 8mm wires.
The 20 meters the car moves, can you tell if it has normal power?
I have to check that.
One problem is that its -4 degrees Farenheit (-20 degrees Celcius)
and the car is outside :D
But i will check how it runs the 20 meters it runs later on.
But as it feels when i revs it a bit its the same as always.
timing belts might be installed improperly. sounds like it's barely running and when put under load (starting to move), it just dies. it doesn't have the power to move.
it's very common to install these belts wrong, they're actually "opposite" in some ways of how other timing belts are installed.
it's also easy to get them a tooth or so off.
vacuum leaks are often a problem too. let it idle and spray starter fluid or carb spray around the engine bay. if there's a vacuum leak the engine will rev/sputter/or die.
is the check engine light on?
your english is superb!
when i mounted the timingbelts wrong it went like sh*t.
Now when i drove it for 30km it went very good and had all the power it should.
Maybe the belt have jumped 1 tooth in the acceleration after the speedbump ?
I have to check the belts one more time.
Can be funny to get this car running, theres only 4 of them left in Sweden.
one thing you may be overlooking is a fuel delivery issue!
remove hose at fuel rail end after fuel filter under hood
conect green test connectors, turn key to on and let fuel flow out, should be strong full stream
Yay Sweden!!!
Johnson;782986']Have you checked the procedure? Here's a good write up.
http://ultimatesubaru.org/forum/showthread.php?t=50768
I have read that and the EA82 Service Manual about 100 times now :D
Done exactly after them.
Everything seems right in the timingmarks but tomorrow i will check som things with MAF, Fuel and the markings one more time.
Its going to be a bit warmer tomorrow :P
I assume that when this trouble happens the engine cranks ok. If that is so you might try spraying some starter fluid into the intake to see if the engine trys to run then. If it still doesn't want to start then I would suspect an ignition problem, most likely due to a bad power connection somewhere.
When i disconnects the MAF the car goes like ************ even on idle.
BUT when i connects the 2 green connectors under the steeringwheel
and turns the igniton switch one step it clicks in some relays
but theres nothing coming from the fuelline after the fuelfilter.
Not before the fuelfilter either.
There not even dripping just nothing :P
Maybe there can be the fuelpump relay or something ?
Or maybe the pump itselfs.
Is an intank pump on this cars ?
fuel pump is under car on fuel filler side, located just before the rear axle
connecting the green connectors puts the computer in test mode, and cycles everything it can, including fuel pump, and waste gate solenoids to help give extra boost when really needed
just lay on your back and stick your head under the car by the wheel
you will see a plate held by 3 bolts 10mm socket to remove
This is just a wild guess
There is a fuse that runs the ECU and the fuel pump.
If the fuse is loose (not likely) or the wire to
the fuse (on the back of the fuse box)
is loose....
Maybe the speed bump knocked it off
just so, it sits and cold or something
causes it to close connection,
20 meters and the vibration causes it to come loose again.
Now it's not making connection and the fuel pump is
not getting it's signal.
Just attempting to connect the speed bump to the problem.
Just for your trouble shooting info
The fuel pump gets battery power (+ 12 Vdc) anytime
the ignition switch is in the run position.
The ECU provides the negative side to the pump
for several seconds after the key is turned to start and released
or
when ever the engine is running.
(and the cycling you hear when the green connectors are connected)
Hope this helps.
wrong-o skip!!
fuse link feeds fuel pump relay for power circuit
fuse feeds fuel pump relay for control circuit
ecm grounds coil in fuel pump relay for control circuit
to "hotwire" pump remove relay and jumper blue to red fat wires
the colors may be different on your year, but the system should be the same
Yeah I also agree that the wire harness for the fuel pulp might be loose. If I remember right, it's a red harness, two wires running just behind the battery on the body rail.
At least mine had this issue. Drove me nutz!! I replaced so many things from my wagon just to find loose wires!
Now i really think that its a loose connection somewhere.
I drove my car for about 10 minutes today without any problems.
And when i was on my way to drive it home it wouldnt start.
What do you think about putting an switch on the fuelpump ?
So i manually puts the pump on.
Is that something that would work ?
Or can there be problems if i do that way ?
Because i cant find the wires under the hood you where talking about.
I dont have any wires at all around the battery.
I've seen a car with a manually wired fuel pump and it caught fire from an oil leak but its very unsafe if you ever get into an accident and it doesn't shut off. Now when you connected the green connectors, did you put the key into the "ON" position and not the "ACC" position? It will only cycle the fuel pump in the "ON" position. Another way to test the fuel pump is to disconnect the line at the fuel rail on the engine and crank it over. If you have fuel at the engine, thats where it'll be. I'm also wondering if there's sediment in the tank that picks up after its running, drops off when its not.
I have also noticed that if the car is cold, the computer will not operate the realy, even if the test connector is connected :banghead:
now I just keep a jumper wire handy for this reason
remove relay and install jumper wire
after car warms up, replace jumper wire with relay and all is good
I suggest if you are going to add a switch, to connect it to the blue and red fat wires of the relay plug so that if the relay were to not turn on the pump, you could turn on the switch which does the same function as the relay
Slightly behind the battery there is a rectangular black box, remove the cover and this is were the fusible links are located. I think its attached to your coolant overflow reservoir.
Ahh that box.
But its no fuses in it :)
Just jumper-wires. As it seems.
But i will check it later on today.
and about the Relay, where is that located ?
Is it next to the hood opener ?
and as Caboobaroo said about sediment.
The car has been standing for 2 years with about
1 gallon of fuel in the tank.
Maybe there has made some sediment.
