Caboobaroo Posted January 11, 2009 Share Posted January 11, 2009 Maybe rust in your tank, tap the fuel filter on the ground and look for rust. Those "jumper wires" are the fuses, they are called fusible links. I'd crimp off the line that goes from the fuel tank to the pump under the car with some vise grips, remove the line from the pump and release the vise grips. Drain it into a coffee can with some sort of paint strainer on it and look for rust or anything else that could be getting clogged in the lines or the tank. If yo do find something, either replace the tank from any fuel injected EA82 car (2wd, 4wd, manual, auto, it doesn't matter) or have it professionally cleaned out. Link to comment Share on other sites More sharing options...
areez Posted January 11, 2009 Author Share Posted January 11, 2009 I will check the tank too. But today i found the real problem. The connection on the fuelpump is loose. And i have to hold it tight together to get the pump going. Tomorrow i'm doing a new connection and hopes for better function. Was no rust in the fuelfilter when i checked it today. Hopefully i can drive the car tomorrow My Grandpa will be really happy now. He bought this car from the Factory 1987 and sold it to my cousins who drove rally with it Or they thought they where It went from mint condition to crappy in 2 years But i think i can get it back up again. Link to comment Share on other sites More sharing options...
subiemech85 Posted January 13, 2009 Share Posted January 13, 2009 the relay is under the steering wheel area by the computer with other relays for headlights, defrost, ignition, etc..... I had to swap fuel tanks due to lagre amount of crud in tank, but now is good I used to have an '87 RX 3door, and sold it about a year later now I drive the '86 gl-10 turbo wagon with ea81 ask any questions you may have Link to comment Share on other sites More sharing options...
areez Posted January 14, 2009 Author Share Posted January 14, 2009 I have an 255L/h Walbro pump at home. hope that will work without any bigger modifications. Link to comment Share on other sites More sharing options...
Skip Posted January 14, 2009 Share Posted January 14, 2009 "But today i found the real problem. The connection on the fuelpump is loose. And i have to hold it tight together to get the pump going." Thanks for the update. The pump you have sounds like a pump for fuel injection? I did not look it up to see. I mean to say, it's not the volume so much as it is the pressure it delivers the fuel at. The factory pump when operating properly is very well suited for the engine in stock form. Link to comment Share on other sites More sharing options...
areez Posted January 14, 2009 Author Share Posted January 14, 2009 So you dont think i should use the Walbro pump instead ? Because here in sweden its almost impossible to find a used pump to this car. And a new one costs 3 times more than a Walbro. The thing with my pump is when its out in the cold its just working when i hit it. But inside it works all the time. And its not the connections that is the problems because i have changed them now. Link to comment Share on other sites More sharing options...
Skip Posted January 14, 2009 Share Posted January 14, 2009 So you dont think i should use the Walbro pump instead ? Because here in sweden its almost impossible to find a used pump to this car. And a new one costs 3 times more than a Walbro. Sir, if it is indeed meant for fuel injection systems yes use it (see below) Your old pump may have had a fuel damper connected directly in line with it. Some people leave it some don't. The thing with my pump is when its out in the cold its justworking when i hit it. But inside it works all the time. And its not the connections that is the problems because i have changed them now. Well this is an entirely different situation. My previous statement was based on the fact that you said "But today i found the real problem. The connection on the fuelpump is loose. And i have to hold it tight together to get the pump going." Link to comment Share on other sites More sharing options...
subiemech85 Posted January 15, 2009 Share Posted January 15, 2009 fuel pump pressures and flow carb 2.6 - 3.3 psi 38L / 10 gmp mpfi 61 - 71 psi max relief valve setting, 95L / 25.1 gpm @ 43.4 psi the pressure regulator adjusts the fuel pressure to 36.3 psi compared to the intake manifold pressure pressure engine at idle 26 - 30 psi pressure with pump on and engine off 37 psi pressure with pump off and engine off 33 psi '85 fsm spfi is approx. 20 psi Link to comment Share on other sites More sharing options...
