johnceggleston Posted January 9, 2009 Share Posted January 9, 2009 (edited) i have some for cheap, but i don't know if they will fit yours. top quality bearings, i just don't have any need for them. http://www.ultimatesubaru.org/forum/showthread.php?t=94608 Edited January 9, 2009 by johnceggleston Link to comment Share on other sites More sharing options...
CNY_Dave Posted January 9, 2009 Share Posted January 9, 2009 i have some for cheap, but i don't know if they will fit yours. top quality bearings, i just don't have any need for them. http://www.ultimatesubaru.org/forum/showthread.php?t=94608 The 6204 bearings are a different size- They are 47, 20, 14mm as opposed to 40, 17, 12. Since it won't fit you should change the part where you say "this part number, 6204-2RSJ, is very close to 6203-2rsj in the 'h6 idler bearing thread'." but instead stick in the sizes I mentioned since it will fit something. Not sure what the sizes are on the others. If you google the part numbers you will turn up what vehicles they fit, most likely. For example, if you google the 6203- number, it comes up on mazda forums. Dave Link to comment Share on other sites More sharing options...
johnceggleston Posted January 9, 2009 Share Posted January 9, 2009 The 6204 bearings are a different size- They are 47, 20, 14mm as opposed to 40, 17, 12. Since it won't fit you should change the part where you say "this part number, 6204-2RSJ, is very close to 6203-2rsj in the 'h6 idler bearing thread'." but instead stick in the sizes I mentioned since it will fit something. Not sure what the sizes are on the others. If you google the part numbers you will turn up what vehicles they fit, most likely. For example, if you google the 6203- number, it comes up on mazda forums. Dave thanks, i did some, will do more. Link to comment Share on other sites More sharing options...
CNY_Dave Posted January 9, 2009 Share Posted January 9, 2009 thanks, i did some, will do more. Hey, just noticed those 203-FF bearings are the right size (did you have the 6203 cross note on there before?), those should work. Is there anything besides '6203' on the bearing itself? Wondering about the manufacturer. Dave Link to comment Share on other sites More sharing options...
johnceggleston Posted January 10, 2009 Share Posted January 10, 2009 Hey, just noticed those 203-FF bearings are the right size (did you have the 6203 cross note on there before?), those should work. Is there anything besides '6203' on the bearing itself? Wondering about the manufacturer. Dave the seal on each side has 6203ul on it so i think that makes it a ntn 6203LLU; which would make it this one. http://www.ntnamerica.com/datasheet.asp?CO_PARTNOSEARCHTYPE=BEGINS&CO_PARTNO=6203&MANUFACTURER=NTN&BEARINGCATEGORY=RBSRD&CSEALSHLD=Double%2Dlip+contact+rubber+seal+both+sides+%28LLU%29&CL_PARTNO=6203LLU& Link to comment Share on other sites More sharing options...
idosubaru Posted February 5, 2009 Share Posted February 5, 2009 I'm about to go buy these bearings and replace mine. 6203-2rsj seems to be the part number mentioned here and the outback forum. NAPA sells a "6203" bearing, so what does the -2rsj stand for? does that mean it's different than 6203 in some way? Link to comment Share on other sites More sharing options...
johnceggleston Posted February 5, 2009 Share Posted February 5, 2009 NAPA sells a "6203" bearing, so what does the -2rsj stand for? does that mean it's different than 6203 in some way? 2rsj means something like rubber seal 2 sides. i have a bunch of these from a subaru mechanics old/ new stock. he retired and sold everything off. there are some web sites where you can look them up. pm sent. http://www.skf.com/skf/productcatalo...did=1050010203 203-ff, unknown bearing also NTN-6203LU, $4.00 shipped outside diameter: 40 mm inside diameter: 17 mm thickness: 12 mm sealed both sides http://www.ntnamerica.com/datasheet.asp?CO_PARTNOSEARCHTYPE=BEGINS&CO_PARTNO =6203&MANUFACTURER=NTN&BEARINGCATEGORY=RBSRD&CSEAL SHLD=Double-lip+contact+rubber+seal+one+side+(LU)&CL_PARTNO=62 03LU& Link to comment Share on other sites More sharing options...
idosubaru Posted February 6, 2009 Share Posted February 6, 2009 I have another 6203 bearing that says 6203-OULX i think on it. So are these all the same bearings? Someone explain the twilight zone music in my head? Link to comment Share on other sites More sharing options...
johnceggleston Posted February 6, 2009 Share Posted February 6, 2009 i think, all 6203 bearings have the same dimensions, the suffix varys per manufacturer. outside diameter: 40 mm inside diameter: 17 mm thickness: 12 mm Link to comment Share on other sites More sharing options...
idosubaru Posted February 6, 2009 Share Posted February 6, 2009 i pm'ed you back, i'll take 'em. Link to comment Share on other sites More sharing options...
