hazard melting fuses
have melted 2 fuses for the hazard flasher, clock, and turn quit working
symptoms: volt guage goes down to 12, lights go dim, fuse melts, car stinks, black smoke, little orange flaming glow only when car is running
it is the middle top row fuse, four from the right :madder:
I still haul a "luggage" in the front seat
I found the problem when I added more "turning signal fluid"
I removed the horn wires on the right side up to the point where they run with all of the wires, the one wire melted the insulation off about a foot in length
IT'S FIXED :banana: !
what is the closest point to the source that I can "disconnect" the horn wires"
notice my "D" horn
