subiemech85 Posted January 13, 2004 Share Posted January 13, 2004 have melted 2 fuses for the hazard flasher, clock, and turn quit working symptoms: volt guage goes down to 12, lights go dim, fuse melts, car stinks, black smoke, little orange flaming glow only when car is running it is the middle top row fuse, four from the right :madder: Link to comment Share on other sites More sharing options...
MilesFox Posted January 13, 2004 Share Posted January 13, 2004 looks like you got a nasty short somewhere. follow along and look for melted wires. maybe a short with one of your turn light circuits Link to comment Share on other sites More sharing options...
junkyardgabe Posted January 14, 2004 Share Posted January 14, 2004 if you don't have time to find it you could put a breaker in place of that fuse Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 14, 2004 Share Posted January 14, 2004 Or some tin foil - but don't do that if you like driving without flames. On the other hand - Skip sets his passenger seat on fire for heat - so I suppose it's all relative..... GD Link to comment Share on other sites More sharing options...
junkyardgabe Posted January 14, 2004 Share Posted January 14, 2004 :-p Link to comment Share on other sites More sharing options...
subiemech85 Posted January 14, 2004 Author Share Posted January 14, 2004 I still haul a "luggage" in the front seat I found the problem when I added more "turning signal fluid" I removed the horn wires on the right side up to the point where they run with all of the wires, the one wire melted the insulation off about a foot in length IT'S FIXED ! what is the closest point to the source that I can "disconnect" the horn wires" notice my "D" horn Link to comment Share on other sites More sharing options...
