xbrandonedgex Posted January 8, 2009 Share Posted January 8, 2009 I just bought a 2000 outback limited wagon with manual trans and so far, I haven't gotten more than 15mpg out of it. It idles rough until it gets up to operating temp, then smooths out for the most part. The plugs, wires, and air and fuel filters were replaced just before I bought it about a month ago. The check engine light has been on for a couple weeks now, but when hooked up to a diagnostic computer, it doesn't show any codes. Anyone else have a similar problem? Are there any common issues with temperature sensors? Thanks for any help Brandon Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted January 8, 2009 Share Posted January 8, 2009 My brothers OB wagon 5 speed has the same issue. The mechanic said it has burnt valves. His needs new heads, or a new engine. Link to comment Share on other sites More sharing options...
nipper Posted January 8, 2009 Share Posted January 8, 2009 Get a better computer. This is getting frustraiting *vent alert* We need the mileage on the car to help tell you whats wrong with it! *vent alert over* Disconnect the battery for ten minutes see if the codes clear, then when the CEL comes back on, get the codes read. Right now you probably have multiplee codes in there. nipper Link to comment Share on other sites More sharing options...
Rooster2 Posted January 8, 2009 Share Posted January 8, 2009 Suggest opening the hood, check to see if the plug wires look new? If they look old and dirty, then maybe the plugs and wires were never changed. Rough idle and poor gas millage is a sure sign that combustion is poor. Pull the codes, as someone said, is a good first start to diagnosing the problem. Link to comment Share on other sites More sharing options...
legacyak Posted January 8, 2009 Share Posted January 8, 2009 Sounds possible that it is the coolant temperature sensor. Link to comment Share on other sites More sharing options...
xbrandonedgex Posted January 8, 2009 Author Share Posted January 8, 2009 My bad on not posting the mileage; 170,000 The plugs and wires are definitely new, I watched the guy change them before he sold me the car. I'll try another computer and see what comes up. Thanks all of you for your help, Brandon Link to comment Share on other sites More sharing options...
nipper Posted January 8, 2009 Share Posted January 8, 2009 !70 can be timing belt, O2 sensor, who knows what else. Get the codes so we can have a starting point. Link to comment Share on other sites More sharing options...
fleming442 Posted January 9, 2009 Share Posted January 9, 2009 FWIW, I cleaned my MAP/ ITS, IAC, replaced my PCV valve, and the hose leading to it. It smoothed the idle out and (knock on wood) the CEL that had a cat code has been out for 4 days. Link to comment Share on other sites More sharing options...
xbrandonedgex Posted January 9, 2009 Author Share Posted January 9, 2009 Okay, I ran the codes on another computer and all I got was Cylinder 1,2, and 4 misfire. Link to comment Share on other sites More sharing options...
nipper Posted January 9, 2009 Share Posted January 9, 2009 What brand of wires? are the spark plug wire ends soaked in oil? What kind of plugs? Can you run the car at night, and with a spray bottle wet the ignition wires and look for sparks? nipper Link to comment Share on other sites More sharing options...
xbrandonedgex Posted January 9, 2009 Author Share Posted January 9, 2009 NGK plugs and wires. And there actually is a little bit of oil on the plug wire boots closest to where it connects to the wires, just on the inside of the shroud on the boot, and it looks like it could easily trail down to the spark plug. hmm... sprayed the wires with a spray bottle while running in the dark, didn't see any sparking. Thanks again for your help nipper and everyone else. Link to comment Share on other sites More sharing options...
nipper Posted January 9, 2009 Share Posted January 9, 2009 Valve cover/bucket leaks will cause misfires like you are seeing. The oil attracts humidity and also breaks down the wire insulation. Link to comment Share on other sites More sharing options...
john in KY Posted January 9, 2009 Share Posted January 9, 2009 Bet it ends up with the coil pack as being the problem. Link to comment Share on other sites More sharing options...
xbrandonedgex Posted January 9, 2009 Author Share Posted January 9, 2009 That makes a lot of sense. Is it possible that as the engine warms up, the oil/ moisture will burn off/evaporate causing the sputtering to go away? Link to comment Share on other sites More sharing options...
nipper Posted January 9, 2009 Share Posted January 9, 2009 That makes a lot of sense. Is it possible that as the engine warms up, the oil/ moisture will burn off/evaporate causing the sputtering to go away? yes. Link to comment Share on other sites More sharing options...
xbrandonedgex Posted January 9, 2009 Author Share Posted January 9, 2009 Awesome! I'll get to work on that ASAP! Thanks for your help and quick responses, nipper!! Brandon Link to comment Share on other sites More sharing options...
nipper Posted January 9, 2009 Share Posted January 9, 2009 I have been wrong before, but thats my best guess. nipper Link to comment Share on other sites More sharing options...
Gloyale Posted January 9, 2009 Share Posted January 9, 2009 I believe the that the all too common Misfire codes in these 2000 outbacks is caused by noise interference between plug wires, and injector wires. They routed them WAY too close to toghether. Make sure that none of the injector wires are actually touching the plug wires. sperate the 2 as much as you can. I've eliminated this reoccuring code by placing flexible wiring conduit around the injector wires, as well as the factory conduit that SHOULD have been swapped onto the new plug wires. Link to comment Share on other sites More sharing options...
brus brother Posted January 10, 2009 Share Posted January 10, 2009 I have been wrong before, but thats my best guess. nipper When? Link to comment Share on other sites More sharing options...
