Caramanos2000 Posted January 12, 2009 Share Posted January 12, 2009 (edited) Did a little searching on here and found two methods I liked, de snorking and cutting the airbox. Can I de snork by removing the plastic inner fender wall or must I remove the whole fender? Between desnorking and airbox cutting what would be better suggested? Is it safe to cut the airbox or do I run the risk of hydrolock? EA-82 BTW ) Edited January 12, 2009 by Caramanos2000 Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted January 12, 2009 Share Posted January 12, 2009 You could get a MAF adapter for a later years Nissan and it bolts to the intake of an EA82...turbo. The SPFI make be different. I did that and put a cone filter on it. What ever you do, make sure that the MAF is supported from bouncing around...it'll destroy the element. Link to comment Share on other sites More sharing options...
