Subaru_dude Posted January 12, 2009 Share Posted January 12, 2009 It's on my EJ22 wiring harness. Just always wondered what it was. http://i136.photobucket.com/albums/q200/SMASHmySOOByDONTya/EJ22%20conversion/DSC_0021.jpg Link to comment Share on other sites More sharing options...
njdrsubaru Posted January 12, 2009 Share Posted January 12, 2009 seen that before and i always thought it was some sort of resistor :confused: Link to comment Share on other sites More sharing options...
Gloyale Posted January 12, 2009 Share Posted January 12, 2009 I believe it is actually a capacitor. there are a few of them scattered in the harness. Probably to supply something like the computer or cruise unit with steady power, no surges. Link to comment Share on other sites More sharing options...
subiemech85 Posted January 13, 2009 Share Posted January 13, 2009 try googling the numbers printed on the black square, also try digikey Link to comment Share on other sites More sharing options...
johnceggleston Posted January 13, 2009 Share Posted January 13, 2009 fusable link? Link to comment Share on other sites More sharing options...
ShawnW Posted January 13, 2009 Share Posted January 13, 2009 They call that a volt controlling diode I think. Limits systems to 12V. I believe the ignition system and the headlight system work thru that perticular one. Don't cut it out and you will be fine. 1/2 of it can be clipped off though. Link to comment Share on other sites More sharing options...
Skip Posted January 13, 2009 Share Posted January 13, 2009 (edited) As Shawn said, I believe it is a Zener diode. From the below link "Zener diodes are widely used to regulate the voltage across a circuit" http://en.wikipedia.org/wiki/Zener_diode Edited January 13, 2009 by Skip Link to comment Share on other sites More sharing options...
zedhead Posted January 13, 2009 Share Posted January 13, 2009 It's either a Diode, or a fusible link. Hook the wire to the battery, with the car running, and measure the output side with a MM. If it's a stable 12 V then it'd be a Diode. If it's 13-14 V Fusible Link Link to comment Share on other sites More sharing options...
bheinen74 Posted January 13, 2009 Share Posted January 13, 2009 it could, be related to the night time dimming.....of like the radio and such..... if it is this, would be nice to tap into for my boost gauge and radio and other such like things lighting.. Link to comment Share on other sites More sharing options...
Subaru_dude Posted January 23, 2009 Author Share Posted January 23, 2009 ShawnW said: They call that a volt controlling diode I think. Limits systems to 12V. I believe the ignition system and the headlight system work thru that perticular one. Don't cut it out and you will be fine. 1/2 of it can be clipped off though. Sorry for the late response. Where would this be found in the car? Behind the dash or under the hood? And if you could give me an exact location that would be helpful so I wouldn't have to spend hours cutting the harness out. I ask because the one pictured isn't my harness and my harness doesn't have that diode, I must have cut it out like an rump roast. Link to comment Share on other sites More sharing options...
