bratman18 Posted January 24, 2009 Share Posted January 24, 2009 kellyray said: I am pretty sure i have the EA81! I have been thinkin this for a while now and cant remember why tho. lol. The starter is on top.. How can i find out FOR SURE what motor I have? Hmmm, if the starter is on top, I dunno. There should be a stamp on the enigine on the front towards the pass. side. It would either say EA81 or EA71. Check around for that stamp. Pics would be best Link to comment Share on other sites More sharing options...
mcbrat Posted January 24, 2009 Share Posted January 24, 2009 sorry I was goofed up there.... there should be an EA81 stamp on top of the block right by the disty. since it's got the top mount starter, the only D/R trans that will fit it is the 1981 GL D/R all others had the side mount starter.... so he would just need to find a bell housing from a later ea81 ... privided of course that it still has the ea81 in it.... Link to comment Share on other sites More sharing options...
bratman18 Posted January 24, 2009 Share Posted January 24, 2009 McBrat said: sorry I was goofed up there.... there should be an EA81 stamp on top of the block right by the disty. since it's got the top mount starter, the only D/R trans that will fit it is the 1981 GL D/R all others had the side mount starter.... so he would just need to find a bell housing from a later ea81 ... provided of course that it still has the ea81 in it.... right. That's what I was thinking. Link to comment Share on other sites More sharing options...
kellyray Posted January 26, 2009 Author Share Posted January 26, 2009 Alright Gents, I have looked every where for a stamped number. All i can seem to find is a number 3. Are yall sure that it would be on there somewhere? It doesnt help that the motor is covered in oil and dirt so its really hard to see anything. Also what do you thing it would be close to? Whats a disty? Not sure what you mean by that. Im getting 4 tires tomorrow and will probably take my brat around in the country for the first time ive had it. Thanks for all of the help!! Kelly O. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted January 26, 2009 Share Posted January 26, 2009 Disty is the typical abbreviation for distributor around here, there should be a casting just to the left of the distributor near the front of the engine or near the oil fill tube near the back of the engine. Spray some carb cleaner or degreaser or something to flean off the old oil if you cant see anything. The casting should say EA81 or EA71. If it says EA81 then the motor is an 1800cc. If its EA71 its a 1600cc. -Bill Link to comment Share on other sites More sharing options...
thermalsurfing1 Posted January 26, 2009 Share Posted January 26, 2009 if i want to buy a gen 1 lift who do i buy it from. Link to comment Share on other sites More sharing options...
kellyray Posted January 26, 2009 Author Share Posted January 26, 2009 4x4brat has some. Link to comment Share on other sites More sharing options...
kellyray Posted January 26, 2009 Author Share Posted January 26, 2009 The Beast I Drive said: Disty is the typical abbreviation for distributor around here, there should be a casting just to the left of the distributor near the front of the engine or near the oil fill tube near the back of the engine. Spray some carb cleaner or degreaser or something to flean off the old oil if you cant see anything. The casting should say EA81 or EA71. If it says EA81 then the motor is an 1800cc. If its EA71 its a 1600cc. -Bill Thanks Bill Link to comment Share on other sites More sharing options...
kellyray Posted January 26, 2009 Author Share Posted January 26, 2009 If you only want a small lift, you can clock the torsion bar spline. From memory you get about an inch and a half from each tooth. I ran mine on 3 clicks (4.5") for a while but the torsion bar actually sticks out so far that you are limited to a 26" tire. Some one has told me this before. Has anyone on here heard of doing this??? Link to comment Share on other sites More sharing options...
4x4brat Posted January 26, 2009 Share Posted January 26, 2009 kellyray said: If you only want a small lift, you can clock the torsion bar spline. From memory you get about an inch and a half from each tooth. I ran mine on 3 clicks (4.5") for a while but the torsion bar actually sticks out so far that you are limited to a 26" tire. Some one has told me this before. Has anyone on here heard of doing this??? Kelly ....Yes this works OK Link to comment Share on other sites More sharing options...
kellyray Posted January 26, 2009 Author Share Posted January 26, 2009 Thought you were snowboarding! Can you do this to the front and rear? Link to comment Share on other sites More sharing options...
4x4brat Posted January 26, 2009 Share Posted January 26, 2009 with two days of Cold freezing rain im back!!! only the rear can be raised this way it will look raked High in the rump roast end and lower in the front:grin: it not good if your trying to get more clearance up front:mad: Link to comment Share on other sites More sharing options...
kellyray Posted January 26, 2009 Author Share Posted January 26, 2009 Figures!!!! thx Link to comment Share on other sites More sharing options...
