foxgap Posted January 15, 2009 Share Posted January 15, 2009 What are you using for a pump on your car. Mine is still working but this fall I had to use the hammer handle trick on it to get it started again. The pump from Subaru is quite expensive and some aftermarkets are not to far away in price. Link to comment Share on other sites More sharing options...
subyfreak Posted January 15, 2009 Share Posted January 15, 2009 I have been told that a 80s-90s Ford F-150 fuel pump will work but I just can not bring my self to put a Ford part on my far superior machine. Worth a look though as there are a hundred Fords for every one Subaru in the scrap yards. Link to comment Share on other sites More sharing options...
Frank B Posted January 15, 2009 Share Posted January 15, 2009 Well, check the repair manual or search here to find the fuel pressure needed. Yours should be SPFI, so around 40-50 psi? I can't remember. Then just find a universal electric fuel pump to put in it's place that puts out the same. Like this one for Fords, in the 80's and early 90's ford used these for both in tank and inline(on the frame). They put out more volume and pressure than the stock Subaru pumps, so you may have to install an extra fuel pressure regulator if the stock one can't handle it. http://cgi.ebay.com/ebaymotors/1985-MERCURY-CAPRI-MARQUIS-COUGAR-5-0-V8-FUEL-PUMP-NIB_W0QQcmdZViewItemQQ_trkparmsZ66Q3a2Q7c65Q3a1Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem280297084050QQitemZ280297084050QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories I put one of these on a GL-10 turbo, and it worked out great. You just have to make sure you get on with the brass hose barbs on each end, and not on that has the filter sock on it(in tank installation). Here's the old post with part numbers. http://www.ultimatesubaru.org/forum/showthread.php?t=40400 Link to comment Share on other sites More sharing options...
Frank B Posted January 15, 2009 Share Posted January 15, 2009 Use those part numbers to cross reference other parts manufacturers to get more part numbers for the part, then search ebay, Rock Auto, even Amazon.com for all the available part numbers to find a deal. Link to comment Share on other sites More sharing options...
Frank B Posted January 15, 2009 Share Posted January 15, 2009 I have been told that a 80s-90s Ford F-150 fuel pump will work but I just can not bring my self to put a Ford part on my far superior machine. Worth a look though as there are a hundred Fords for every one Subaru in the scrap yards. Well, just keep in mind that neither Ford or Subaru make the replacement fuel pumps, or the original in some cases. Link to comment Share on other sites More sharing options...
presslab Posted January 15, 2009 Share Posted January 15, 2009 I have that Ford pump in my EA82T pushing 15 PSI boost with no problems; I set my static fuel pressure to 60 PSI, up from stock of 36 PSI. Mine came with a short elbow hose that I used to redirect the output 90 degrees like the stock pump. Link to comment Share on other sites More sharing options...
Numbchux Posted January 15, 2009 Share Posted January 15, 2009 I got one for a '90 Ford Grand Squire wagon on ebay for about $30 and used it in the '86 wagon that I EJ-swapped last summer. worked great! Link to comment Share on other sites More sharing options...
foxgap Posted January 15, 2009 Author Share Posted January 15, 2009 Thanks a ton all!!!!!!! I will start hunting all this info down and get a spare soon. I just know the bugger will give out in the middle of a snow storm when I need the car the most. Mark Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 16, 2009 Share Posted January 16, 2009 (edited) I Believe (But I`m Not 100% Sure) that the ER27 Engine`s fuel Pump can work well on FI EA82`s ... Edited January 16, 2009 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
somick Posted January 16, 2009 Share Posted January 16, 2009 Could somebody provide a part number for Ford's fuel pump? I have the same problem with my Loyale's. Hit it with a hammer handle and it works now but who know how long it will last. So I want to be ready... Thanks in advance, Sam Link to comment Share on other sites More sharing options...
somick Posted January 16, 2009 Share Posted January 16, 2009 I found another thread where Skip points at this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=40400&highlight=ford+fuel+pump Sam Link to comment Share on other sites More sharing options...
Frank B Posted January 16, 2009 Share Posted January 16, 2009 Could somebody provide a part number for Ford's fuel pump? I have the same problem with my Loyale's. Hit it with a hammer handle and it works now but who know how long it will last. So I want to be ready... Thanks in advance, Sam Look at the link in my first post in this thread. Link to comment Share on other sites More sharing options...
Caramanos2000 Posted January 17, 2009 Share Posted January 17, 2009 (edited) Most pumps off 1980s Nissans will work including the one from a 6 cylinder 1982 Maxima. Thats what I currently have also :banana: BTW mine is SPFI> Edited January 17, 2009 by Caramanos2000 Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted January 17, 2009 Share Posted January 17, 2009 (edited) I got one for a '90 Ford Grand Squire wagon on ebay for about $30 and used it in the '86 wagon that I EJ-swapped last summer. worked great! did you have a carb'ed model? i was planning on feeding the ej with the spfi pump i already retrofitted into my hatch and i've been wondering if it'll work well. Edited January 17, 2009 by mountaingoatgruff Link to comment Share on other sites More sharing options...
Numbchux Posted January 18, 2009 Share Posted January 18, 2009 the '86 was carbed. the EJ22 I dropped in it was N/A. N/A EJ22s and SPFI EA82s have almost the exact same "needs" (psi and cfm). so if it works for your SPFI, it'll work with the EJ22. Link to comment Share on other sites More sharing options...
