frogstar7055 Posted January 16, 2009 Share Posted January 16, 2009 2" with camber offsets. Next locker switch. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted January 17, 2009 Share Posted January 17, 2009 Awesome! Link to comment Share on other sites More sharing options...
crash321 Posted January 17, 2009 Share Posted January 17, 2009 Ideas, Ideas, now if I can only get the wife to get on board! Link to comment Share on other sites More sharing options...
bigo1966 Posted January 17, 2009 Share Posted January 17, 2009 How much lift, how did you do it. how long did it take. Link to comment Share on other sites More sharing options...
frogstar7055 Posted January 18, 2009 Author Share Posted January 18, 2009 How much lift, how did you do it. how long did it take. 2" of lift. I'm a machinist. Worked on it off and on for about 3 months. Link to comment Share on other sites More sharing options...
bratman18 Posted January 18, 2009 Share Posted January 18, 2009 It does look good! Do you have any pics of the actual lift that you made and installed? Link to comment Share on other sites More sharing options...
frogstar7055 Posted January 18, 2009 Author Share Posted January 18, 2009 It does look good! Do you have any pics of the actual lift that you made and installed? Here you go. 2" of lift with .236 offset. It rides and tracks perfect,get wheel alignment Tuesday. Fronts(not yet painted) Rear I actually washed it for this shot(not something I'm usually inclined to do). Link to comment Share on other sites More sharing options...
bratman18 Posted January 18, 2009 Share Posted January 18, 2009 Very nice!! You should whip up a few sets and sell them!! Link to comment Share on other sites More sharing options...
frogstar7055 Posted January 18, 2009 Author Share Posted January 18, 2009 (edited) Just a side note, My CV's were original's (115000mi). They fronts made noise and vibrated so I replaced them both and now it's smooth as glass. I think the old CV's were worn to the angle they had run at all those years and didn't like the change in angle. Rears seem fine but I'll probably replace those as well before to long. Edited January 18, 2009 by frogstar7055 Link to comment Share on other sites More sharing options...
bratman18 Posted January 18, 2009 Share Posted January 18, 2009 Just a side note, My CV's were original's (115000mi). They made noise and vibrated so I replaced them both and now it's smooth as glass. I think the old CV's were worn to the angle they had run at all those years and didn't like the change in angle. Rears seem fine but I'll probably replace those as well before to long. It probably wouldn't be to hard to whip up some blocks for the crossmembers as well to correct the cv angle Link to comment Share on other sites More sharing options...
frogstar7055 Posted January 19, 2009 Author Share Posted January 19, 2009 It probably wouldn't be to hard to whip up some blocks for the crossmembers as well to correct the cv angle Figure if it looks like it's gonna wear them out prematurely that's what I'll do. Link to comment Share on other sites More sharing options...
superu Posted March 17, 2009 Share Posted March 17, 2009 (edited) Very nice!! You should whip up a few sets and sell them!! 2nd! Edited March 17, 2009 by superu typo Link to comment Share on other sites More sharing options...
Gloyale Posted March 17, 2009 Share Posted March 17, 2009 It probably wouldn't be to hard to whip up some blocks for the crossmembers as well to correct the cv angle Yeah, but then he'd be right back to stock clearance at the diffs. Link to comment Share on other sites More sharing options...
bratman18 Posted March 17, 2009 Share Posted March 17, 2009 Yeah, but then he'd be right back to stock clearance at the diffs. Yup, but if he has any problems with CV angle it wouldn't be too hard to correct it. Link to comment Share on other sites More sharing options...
frogstar7055 Posted March 17, 2009 Author Share Posted March 17, 2009 Yeah, but then he'd be right back to stock clearance at the diffs. More than a thousand miles and A-OK. In future may make 4' strut top spacers and go 2" on everything else. More involved than that I know but I like making mods. Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted March 23, 2009 Share Posted March 23, 2009 In future may make 4' strut top spacers and go 2" on everything else. 4 feet!!! but really, how hard was it to make these? as in, how did you calculate offset? Link to comment Share on other sites More sharing options...
frogstar7055 Posted March 24, 2009 Author Share Posted March 24, 2009 4 feet!!! but really, how hard was it to make these? as in, how did you calculate offset? 4 foot! I must be nutz:banana: I asked a lot of questions of our Aussie brothers and trigged it out myself and came up with 6mm of offset. Worked but not quite enough,had to put camber bolts in rear. Should have went 7mm. (3.5mm per inch of lift) Link to comment Share on other sites More sharing options...
thatswhatshesaid Posted March 24, 2009 Share Posted March 24, 2009 So, old buddy...what's the likelihood you'll be pumping out a few more of these kits for us to buy? Link to comment Share on other sites More sharing options...
frogstar7055 Posted March 24, 2009 Author Share Posted March 24, 2009 So, old buddy...what's the likelihood you'll be pumping out a few more of these kits for us to buy? Was a lot of work,had to use some equipment at my work and can't do that all the time. Jackson Rally over on dirtyimpreza.com makes a 1" lift and is supposed to be working on a 2" kit as well. Link to comment Share on other sites More sharing options...
lostinthe202 Posted December 21, 2009 Share Posted December 21, 2009 How about an update? Any axle problems? How about your mileage? Auto or manual? Thanks! Will- Link to comment Share on other sites More sharing options...
superu Posted December 21, 2009 Share Posted December 21, 2009 +1 I'm curious how your axles are dealing with the new angles and forces of the lift. OOH and I'd like to hear your perspective on the phantom grip, now that you've been running it for a while in different conditions, on and off road. Thanks! -mw- Link to comment Share on other sites More sharing options...
frogstar7055 Posted December 26, 2009 Author Share Posted December 26, 2009 Got about 4000mi on the lift and all CV's are fine. Don't have the Phantom grip,was just considering it. I have done the 4eat lock(sorta)switch and that works FANTASTIC in soft loose sand. Done a lot of mods,wouldn't go back on any of them. Link to comment Share on other sites More sharing options...
lostinthe202 Posted December 26, 2009 Share Posted December 26, 2009 Sweet, good to know. How's your mileage? Link to comment Share on other sites More sharing options...
frogstar7055 Posted December 26, 2009 Author Share Posted December 26, 2009 17 to 20mpg in town depending on how heavy my right foot is at the time. 24+ mpg on the highway depending on where the cruise is set,headwinds,etc. Highest I've got was 28mpg out of a tank on the highway coming back from WV. Link to comment Share on other sites More sharing options...
