Made a lift kit
frogstar7055
It does look good! Do you have any pics of the actual lift that you made and installed?
Here you go.
2" of lift with .236 offset.
It rides and tracks perfect,get wheel alignment Tuesday.
Fronts(not yet painted)
Rear
I actually washed it for this shot(not something I'm usually inclined to do).
Just a side note,
My CV's were original's (115000mi).
They fronts made noise and vibrated so I replaced them both and now it's smooth as glass. I think the old CV's were worn to the angle they had run at all those years and didn't like the change in angle.
Rears seem fine but I'll probably replace those as well before to long.
Edited by frogstar7055
Just a side note,
They made noise and vibrated so I replaced them both and now it's smooth as glass. I think the old CV's were worn to the angle they had run at all those years and didn't like the change in angle.
It probably wouldn't be to hard to whip up some blocks for the crossmembers as well to correct the cv angle
  • 1 month later...
4 feet!!! :eek::lol:
but really, how hard was it to make these? as in, how did you calculate offset?
4 foot! I must be nutz:banana:
I asked a lot of questions of our Aussie brothers and trigged it out myself and came up with 6mm of offset.
Worked but not quite enough,had to put camber bolts in rear.
Should have went 7mm. (3.5mm per inch of lift)
So, old buddy...what's the likelihood you'll be pumping out a few more of these kits for us to buy?
Was a lot of work,had to use some equipment at my work and can't do that all the time.
Jackson Rally over on dirtyimpreza.com makes a 1" lift and is supposed to be working on a 2" kit as well.
  • 8 months later...
+1
I'm curious how your axles are dealing with the new angles and forces of the lift.
OOH and I'd like to hear your perspective on the phantom grip, now that you've been running it for a while in different conditions, on and off road.
Thanks!
-mw-
