Is this the ECU?
led should be at the "top" end of the silver box, towards the steering wheel
push the big bundle of wires out of the way, trun key on and look for flash
looks nothing like the old style '86 box :eek:
correct. Once you know where the light is, you won't need to remove the kick panel to check it. You just need to look straight down the steering column to see it.
That is what my chilton said too... but I just can't find the LED... I have looked around, pushed the wires aside and stuff and it just doesn't seems to be there.
I turn the key to on and expect I'll catch some fleshing light but nope... nothing happen as far as I can see.
Anyone can upload a pic of where it suppose to be?
There is a hole in the front of the unit.
Front being the skinny face that is closest to the driver.
The light is kinduv down inside the hole. Look harder, it is there.
If it isn't lighting at all, you have a lack of power to the ECU.
to follow up what Gloyale says
this light is also known as the
oxygen monitor light
It is right where he says.
This is an older unit but the light hole
should be the same.
You might want to plug together your green connectors
by the drivers side hood hinge
This will make the light flash.
Key must be in the run position
for it to flash.
should be the same.
for it to flash.
Run position, but does the Eng needs to be running too?
