86' Brat GL timing belt?
i'm confused as to whether the 86' Brat GL EA81 has a timing belt/chain or not.
Can anyone help me on this? Also
Is it better to do a Hitachi carb upgrade or a Weber 32/36 replacement?
Thanks
Edited by GR86BRAT
i'm confused as to whether the 86' Brat GL has a timing belt/chain or not.
The Brat/ EA81 does not have a timing belt or chain, it is all internal gear driven.
Thanks Bratman 18,
Any views on the Hitachi upgrade or Weber 32/36 replacement?
I've seen a lot of people using the weber. I personally have the fuel injection conversion done to my Brat so I can't help with specifics
Edited by bratman18
4 gears run the system
rear crank drives rear cam, rear cam, front crank drives dist, dist.
you can upgrade to ea82 hitachi carb and intake system -- this is the current method that yields good results and 20+mpg in gen3 wagon, cruises right along at 3k rpm
you can upgrade to ea81 hitachi carb and intake system
you can upgrade to the weber carb and intake system of your choice
avoid the carter / weber system, as I am assuming you are trying to upgrade from
Thanks subiemech85,
I currently have the regular Hitachi system on my car but it seems acording to post here that the weber setup is much better. I was happy with that info until I seen a Hitachi upgrade post. Which one gives the most bang for the buck?
Edited by GR86BRAT
