83 Brat Turbo Update
No time to bring the camera today so I used the cell phone for a couple of shots of what I have done. Basically clean out the entire cowl the best I could of all debris, rust and previous repair attempts. Then treat the entire length of the cowl with POR-15 Black and let it start to set up. Install the mat in pre-cut sections made with paper templates start at the end and overlap toward the middle piece. It will be the highest and last piece put in. Let this all set up hard and then before it's totally cured another coat of POR-15 over the top to insure it's rigid and water tight. The after shot didn't turn out looking well with the phone cam but you get the idea. This shouldn't ever leak or rust through again. I did the whole cowl this way. The new heater core and dash will get installed Monday morning after I replace all the dash lamps and tighten all the gauge connections. (Click for larger pictures)
Edited by XT6 Magic
Well, this was supposed to be a good/quick temporary fix. I removed all the flakey loose rust that I could get to and converted the rest with POR-15. It seals out oxygen/moisture and dramatically reduces the chances of short term damage. Then, according to the manufacturers directions I rebuild the vacant sections with fiberglass mat and re-coated it again.
The problem is I can't weld sheet metal yet (no equipment/no practice) and I need to keep the car from being a swimming pool/mushroom farm:rolleyes: until I find a better solution. Perhaps this will even be permanent, who knows. The dash comes out in just a few minutes and the weather will improve soon. In a better world I would have found a donor car, cut the required sections larger than needed, and then fit and welded them in. That will have to wait.
-Jeff
Edited by XT6 Magic
So far it feels like concrete with a ceramic surface. Of course that doesn't mean it won't all bounce loose on the first pothole:grin:
Yeah that's my fear. I mean the actual surface will be rock solid but how well did it bond to the sheet metal? That's the question
Looks good! I always took a propane torch and lightly went all over the surface of the bumpers. It made them go right back to a nice semi-glossy black. It always worked great for me. Just make sure you don't hold it in one spot....obviously it will burn if it gets too hot
