The Scooby Posted January 17, 2009 Share Posted January 17, 2009 im getting ready to drop in the EJ22 into my 86, and wanted to see some pictures of what it looks like, how you did the intake system, fuel lines, etc. its a 98 longblock with a 93 intake and wiring going into a 86 carbed wagon. Thanks, Shean Link to comment Share on other sites More sharing options...
Phizinza Posted January 18, 2009 Share Posted January 18, 2009 The first setup for intake I had on the Brumby I don't have a picture of the setup it had when I sold it, but it was basically the same pod filter and MAF coming straight out of the TB using a straight rubber pipe. The reason I done this is I went in some deep water that came above the battery and my pod filter got wet. Luckily my engine was ok. Link to comment Share on other sites More sharing options...
Numbchux Posted January 18, 2009 Share Posted January 18, 2009 my pm page isn't working now....fuel lines are easy. the carbed car has a high-pressure line, return line, and vent. and so does the EJ. Link to comment Share on other sites More sharing options...
crockettbrat Posted January 18, 2009 Share Posted January 18, 2009 I used the stock ej airbox. I drilled a hole is the side of the fender wall for the mounting nub on the side of the box and chopped a little off the bottom edge of the box and lost the snorkel that lives in the ej fender. Here are some pics. Good luck on the swap! You're going to love it! Daniel maybe someday I'll learn how to resize pics. Sorry they're so big. Link to comment Share on other sites More sharing options...
kingbobdole Posted January 18, 2009 Share Posted January 18, 2009 EJ25 in 88 rx Link to comment Share on other sites More sharing options...
Pooparu Posted January 18, 2009 Share Posted January 18, 2009 1982 Subaru Hatch with '93 ej22 I'm working on getting this intake set-up to work. Link to comment Share on other sites More sharing options...
Lazer Posted January 18, 2009 Share Posted January 18, 2009 ej20g in a xt turbo Link to comment Share on other sites More sharing options...
The Scooby Posted January 19, 2009 Author Share Posted January 19, 2009 sweet i can't wait to get mine done, thanks for the pictures, its helping me sort out some of the stuff i need to do yet. Link to comment Share on other sites More sharing options...
Subaru_dude Posted January 19, 2009 Share Posted January 19, 2009 Where do you guys put the ECU? I've thought about just leaving mine sitting in some kind of container where the spare goes. Link to comment Share on other sites More sharing options...
baccaruda Posted January 19, 2009 Share Posted January 19, 2009 (edited) My wagon's EJ ECU is in the same spot as the stock one - under the steering column. It's zip tied on until I make a way to bolt it to the column as the stock one was. I think I'll probably get another Legacy harness and re-do the wiring swap so I can do a neater job under the dash and at the engine bay inlet. Edited January 19, 2009 by baccaruda Link to comment Share on other sites More sharing options...
Numbchux Posted January 19, 2009 Share Posted January 19, 2009 ^ditto. both the swaps I've done, I've mounted the ECU to the steering column. Link to comment Share on other sites More sharing options...
The Dude Abides Posted January 19, 2009 Share Posted January 19, 2009 One of the few things holding me back from this is the wireing. Man looks like a rats nest. Link to comment Share on other sites More sharing options...
SubaruJawn Posted January 19, 2009 Share Posted January 19, 2009 I To Am Afraid of the Wiring. mostly afraid of the Dash. on how to take it apart from legacy. i was told you don't have to take the loyal dash out in order to do the wiring. is this true ? I Look Forward to doing this swap. just wish i had a loyal thats in better shape. Link to comment Share on other sites More sharing options...
baccaruda Posted January 19, 2009 Share Posted January 19, 2009 Correct. I took my dash out so I could R&R the heater but it was back in before I put in the wiring. It would be easier to do the best, cleanest job if you did take out the dash, though. You do need to pull the dash cluster and its surround to graft in the wires for the ECU light and gauges but that's easy stuff... Link to comment Share on other sites More sharing options...
Numbchux Posted January 19, 2009 Share Posted January 19, 2009 rats nest? ha. finished OBD II harness ready to be installed: as much dash disassembly that was required. using a hole saw to cut a hole in the firewall for the wiring: engine installed (AND wired. and it only got cleaner!!) Link to comment Share on other sites More sharing options...
SubaruJawn Posted January 19, 2009 Share Posted January 19, 2009 (edited) Numbchux said: rats nest? ha. finished OBD II harness ready to be installed:using a hole saw to cut a hole in the firewall for the wiring: you use the ea trans ? thats what it looks like. Edited January 20, 2009 by SubaruJawn Link to comment Share on other sites More sharing options...
The Scooby Posted January 20, 2009 Author Share Posted January 20, 2009 ya it is Link to comment Share on other sites More sharing options...
Pooparu Posted January 20, 2009 Share Posted January 20, 2009 Subaru_dude said: Where do you guys put the ECU? I've thought about just leaving mine sitting in some kind of container where the spare goes. I put mine behind the glove box with some zip ties. Everything went back into place very nice. Link to comment Share on other sites More sharing options...
ShawnW Posted January 20, 2009 Share Posted January 20, 2009 If I had to do it over again I would put mine down on the floorboard like the WRX has it on the passenger side foot board. Mine is currently IN the glovebox along with the IGN relay, FP relay and the ignitor if I remember correctly. I also put the memory and D-Check connectors here as well. Link to comment Share on other sites More sharing options...
kingbobdole Posted January 20, 2009 Share Posted January 20, 2009 Don't put it in the spare tire area... I did it once and it looked really bad. No where to hide the "mess". +1 on wiring not being too bad on the early EJs... maybe three pages of diagrams. OBD 2 is not too much worse, here's my harness ready for install into the EJ25 Rx. Only three power wires and a few grounds to hook up. The EZ30 harness was a pig though ten pages.... that one took me a while. Link to comment Share on other sites More sharing options...
Numbchux Posted January 20, 2009 Share Posted January 20, 2009 for those concerned about install of a wiring harness. here's the page of info I send out with a stripped harness. http://www.numbchuxconversions.com/Files/Harness%20info.pdf Link to comment Share on other sites More sharing options...
Phizinza Posted January 21, 2009 Share Posted January 21, 2009 Wiring...? Thats the fun bit Top one is after I pulled it from the EJ. Next is it cut down getting tested. Final 3rd is it ready to go in all clean. This bit was fun, just chop chop chop Link to comment Share on other sites More sharing options...
Pooparu Posted January 23, 2009 Share Posted January 23, 2009 Ya yes wiring is fun. As long as you have a good friend who knows what they are doing. Link to comment Share on other sites More sharing options...
The Scooby Posted January 25, 2009 Author Share Posted January 25, 2009 ok quick question on the fuel system. my wagon is a 86 carbed, im swapping in the SPFI pump, the feed to the engine will work fine, but the inlet into the pumpis majorly different sizes. waht i did on the return line was get 2 pipe fittings, 1 was 1/4 male, then a 1/4inch double female, then a 5/16th's end so i can hook up at teh EJ intake and hook to the factory return line. should i just do the same, 3/8th's to a coupler to a 5/16th's adapter for the inlet into the fuel pump from the tank? also these are the brass fittings i found at a local auto parts store, should be fine right? Link to comment Share on other sites More sharing options...
Numbchux Posted January 26, 2009 Share Posted January 26, 2009 hmmm...the ford pump plugged right into lines on the '86. all I had to do was throw a couple real screw-on clamps on there. might have been a fluke with the ford pump though. that pump came with all brass fittings, so I'd assume they're safe to run fuel through Link to comment Share on other sites More sharing options...
