Post pictures of your EJ swap
The Scooby
It's not really that hard or time consuming. I went to the junk yard and pulled fuel lines for EFI Subarus and it didn't cost me anything, and it took me all of 5 to 10 minutes to replace all the rubber lines in the car. Any job worth doing is a job worth doing right. I know you might be eager to get your car going but cutting corners now will be much more costly and time consuming in the end. Trust me, take the time.
It loops in and out of the legacy. Just start pulling everything out, and you'll have to get into the driver's side fender as well. I found it to be easier to just take it off. Sorry no pic of the carnage.
ok. so it doesn't go threw the firewall ?
(trying to build confidence on the swap)
Last dash I pulled took me about an hour to get out and I had to be nice (just doing a heater core) There are surprisingly few bolts holding it in... just get it out of the way.
ok don't see were the wires are at.
P.S
Will i have any problems with the exhaust fitting ?
Edited by SubaruJawn
  • 2 years later...
