howards11 Posted January 14, 2004 Share Posted January 14, 2004 I need some suggestions on a 30,000 mile checkup on my 2000 Forester L. Here's what I'm going to have done: 1. Oil change (5W30 dino), lube, filter. 2. 4 wheel alignment 3. Change antifreeze 4. Replace fuel filter 5. Check all fluids and hoses (esp. the differental fluids) 6. Check timing belt I believe Subaru suggests a change of brake fluid. Should this really be done ? Are there any other items I'm missing ? Thanks for your help ! ~Howard Link to comment Share on other sites More sharing options...
ShawnW Posted January 14, 2004 Share Posted January 14, 2004 I did a search and found these 3 threads of relevance: http://www.ultimatesubaru.org/usmb/forum/showthread.php?s=&threadid=6721&highlight=30000 Link to comment Share on other sites More sharing options...
BlueSoob Posted January 14, 2004 Share Posted January 14, 2004 WOW!! LOW MILEAGE MAN! I'm on a 2003 w/ 40,000 mi you don't drive much do you? Link to comment Share on other sites More sharing options...
AZP Installs Posted January 14, 2004 Share Posted January 14, 2004 Originally posted by howards11 I need some suggestions on a 30,000 mile checkup on my 2000 Forester L. Here's what I'm going to have done: 1. Oil change (5W30 dino), lube, filter. 2. 4 wheel alignment 3. Change antifreeze 4. Replace fuel filter 5. Check all fluids and hoses (esp. the differental fluids) 6. Check timing belt I believe Subaru suggests a change of brake fluid. Should this really be done ? Are there any other items I'm missing ? Thanks for your help ! ~Howard Shoot me an e-mail, we are relatively close, might be worth the drive up to our place for some TLC. -mike Link to comment Share on other sites More sharing options...
mtsmiths Posted January 14, 2004 Share Posted January 14, 2004 Them easterners don't git out much do they? Link to comment Share on other sites More sharing options...
Guest lothar34 Posted January 14, 2004 Share Posted January 14, 2004 What about rotating the tires? Link to comment Share on other sites More sharing options...
99obw Posted January 15, 2004 Share Posted January 15, 2004 Originally posted by howards11 I need some suggestions on a 30,000 mile checkup on my 2000 Forester L. Here's what I'm going to have done: 1. Oil change (5W30 dino), lube, filter. 2. 4 wheel alignment 3. Change antifreeze 4. Replace fuel filter 5. Check all fluids and hoses (esp. the differental fluids) 6. Check timing belt I believe Subaru suggests a change of brake fluid. Should this really be done ? Are there any other items I'm missing ? Thanks for your help ! ~Howard Also change air filter and PCV valve. Have the brakes dissasembled and the slides lubricated. Lubricate the door hinges. Definately have the brake fluid changed with that many years and only 30k miles. Change the tranny fluid (and filter if auto) and differential fluids. I think checking the timing belt at 30k is a waste of time. Link to comment Share on other sites More sharing options...
SevenSisters Posted January 15, 2004 Share Posted January 15, 2004 Not to dissuade you from an alignment, but my ’91 never been aligned and exhibits no irregular or fast tire wear. Ask the service manager to look at your tires and tell you if and why you need an alignment. Lothar34 suggested a rotation which should be performed every 5-6K miles and may be more important IF you are not having a tire wear problem. By the way, replace the brake fluid. It will save you problems with component corrosion in the long run. Air filters and plugs are probably 30K items too. Link to comment Share on other sites More sharing options...
howards11 Posted January 15, 2004 Author Share Posted January 15, 2004 Car was purchased in May, 2003 with about 25,000 miles. Tire rotation: Tires were replaced around Xmas. The 4 wheel alignment is being done because on the Friday after Thanksgiving I was rear ended @ about 20-25 mi. The Pontiac Bonneville that hit me slid under the Forester and wiped out the exhaust system along with some body damage to the hatch and bumper. My body shop guy told me that the wheel alignment was off a tad but the insurance company would not pay for it. This is the first opportunity I have had to take the car in for it. 90% of the driving I do is city driving. ~Howard Link to comment Share on other sites More sharing options...
