88whitecat Posted January 18, 2009 Share Posted January 18, 2009 From the searcing I've done, rear axles are the same for both Legacys and outbacks 95-99. I am swapping the rear diff in my 96 outback with one from a 98 legacy L yet the axle stubs are not sliding into the new diff? Was there a spline count change or something else that would cause this? Or do I just need to give it a harder push? Link to comment Share on other sites More sharing options...
bratman18 Posted January 18, 2009 Share Posted January 18, 2009 From the searcing I've done, rear axles are the same for both Legacys and outbacks 95-99. I am swapping the rear diff in my 96 outback with one from a 98 legacy L yet the axle stubs are not sliding into the new diff? Was there a spline count change or something else that would cause this? Or do I just need to give it a harder push? I bet the diff gear ratio is different between the Legacy and the outback Link to comment Share on other sites More sharing options...
88whitecat Posted January 19, 2009 Author Share Posted January 19, 2009 It is in fact different. It had a 4.44 and I am putiing in a 4.11 to match the tranny that now resides in her. The trouble is that after dropping the old diff, the axle stubs are just stopping with 1" left to go sliding into the (98)diff. According to Opposed Forces the axles are the same from 94 thru 98 for nearly all legacys and nothing was damaged in removal. I should mention that when I gave up I reinstalled the old diff and it went like butter! Had I known there was a difference ahead of time I would have grabbed the axles I have in the garage that are known to fit and brought them with me to where I was working on the car. Link to comment Share on other sites More sharing options...
wtdash Posted January 19, 2009 Share Posted January 19, 2009 (edited) I did a quick check online (autozone - do not buy from them!) and the part numbers are the same for both of your years/models of Legacy - the only diff (pun intended) is Left and Right...on the rear CV axles only. However, when I looked on 1st Subaru Parts website, there is a listing for '95-97 and '98-2000 for the Legacy.... I don't know what, if any, difference there is. I also thought they were all the same, so I had to look for my own info. Also, since there is no distinction for '96-97 axles between Outback and L models online, the rear diff ratio shouldn't matter. Since you have the '98 axles, too, I guess you're good to go...however, swapping a rear diff is a PITA....esp. twice. Edited January 19, 2009 by wtdash add diff info Link to comment Share on other sites More sharing options...
88whitecat Posted January 19, 2009 Author Share Posted January 19, 2009 Thanks Dash for the confirmation. It wasn't too bad. Despite alot of new england rust it came apart pretty easy. When I go to do this again at least everything is already broken free and and will go quickly. Its also nice that we have a heated, drive-in warehouse where I work so I'm not freezing my balls off outside. Link to comment Share on other sites More sharing options...
johnceggleston Posted January 19, 2009 Share Posted January 19, 2009 i'm confused. did the axle stubs not fit into the rear diff or did the axles not fit on the stubs??? Link to comment Share on other sites More sharing options...
88whitecat Posted January 19, 2009 Author Share Posted January 19, 2009 The stubs did not fit into the diff. The stubs do not remove from the rear axle. Link to comment Share on other sites More sharing options...
idosubaru Posted January 19, 2009 Share Posted January 19, 2009 so what was the final verdict - the 98 and 96 rear axles are not the same? Link to comment Share on other sites More sharing options...
88whitecat Posted January 19, 2009 Author Share Posted January 19, 2009 Based on my experience yesterday and what dash found I think that we are saying they are different. When I reattempt the job probably wednesday or thursday I will compare them side by side. Count the splines on each and measure the overall diameter to conclude the matter. Link to comment Share on other sites More sharing options...
oooo Posted June 4, 2009 Share Posted June 4, 2009 Did you ever get a conclusive answer on this? Link to comment Share on other sites More sharing options...
