bigwhite4x4 Posted January 24, 2009 Share Posted January 24, 2009 what all do i have to do and what parts will i need to go form a ea81 to ea81t Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 24, 2009 Share Posted January 24, 2009 You`ll Need an EA81T Engine! ... is Better to Swap the Entire Engine for Sure. Better than that, you can Swap an EJ Engine there too ... ... Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 24, 2009 Share Posted January 24, 2009 The EA81 and EA81T heads are completely different. The engines themselfs are different. EA81's are carburated EA81T's are MPFI There is a computer that controls the EA81T. Each head has fuel injection ports. The pistons are different to lower compression ratio. If you wanted to cheat, you could do a SPFI conversion and bolt on a Turbo. But the ECU that runs a SPFI may not operate correctly if intake manifold pressure goes into the positive. Link to comment Share on other sites More sharing options...
bratbill Posted January 24, 2009 Share Posted January 24, 2009 wiring harness is different,battery on other side.Radiator is larger,fuel tank,pump and lines are different. Link to comment Share on other sites More sharing options...
carfreak85 Posted January 25, 2009 Share Posted January 25, 2009 engine and cabin front wiring harnesses are different as well. Some suspension parts too. Link to comment Share on other sites More sharing options...
