horrid Cold starting
well I didnt want to hijack someone else's post on cold starting so I fingered I'd start my own:
started my car this am.. -9 F outside..it was down to -30 F last night.
now for my car.. my sig. says what it is. (hitachi POS)...
pumped the pedal 3 times, started it and it idled at like 350 rpms and felt like it was runnin on 3 cylinders. reved it u a lil bit, seemed to run a lil better but it was still running ruff (car was bouncin around) after the car sputters for about 2 min, it revs it self back up to normal idle and runs great...
and my fast idle hasnt worked since I got the car.
Question 1: Fast idle must be busted, is there something that breaks on it witha hitachi?
Question 2: my choke doesnt seem like it works either. Do the acutators go out in them and how fixable is it?
Question 3: anyone havea mechanical choke wired in on a EA82 hitachi?
alright.. thanks guys..
northguy - I doubt its icing in the carb. I checked the vacumn deal last year and it was working fine. My car only does it when its very first started.. runs like **** for about a minute and then something kicks in (prolly the choke) and it runs good
If I can find a compression tester to use, I'ma do it this weekend..
Comp testing is just pulling the plug out and screwing in the fitting to the tester and cranking the engine correct?
