420 code, please confirm that I'm taking the correct step
2000 OBW, man trans, 144k miles
After repairing the wiring harness for my vapor recovery canister, I went to clear the code and noticed that there were 2 codes, one the vapor recovery canister, and the other was the dreaded 420.
The cats and the front O2 sensor were replaced at about 135k miles.
My plan is to blindly replace the rear O2 sensor with a new one with the assumption that it's the only old part that could throw this code.
Sound like the right way to go?
Or should I take the car to the exhaust shop and let them go through their diagnostics?
Thanks a bunch
Clear it and see if it comes back.
this is a code that can show up from a bad batch of gas, other things in the engine wrong, cold cold weather.
Did you have a genuine Subaru O2 put in the front? If not htat could be you'r problem.
It is a genuine Subaru part up front.
I have reset the code 2x now. The first time it came back about 4 hours later. The second time it took 24 hours.
It's been cold here in Seattle, but not "cold, cold." To me, "cold, cold" is like North Dakota cold. Granted, the car isn't used to this kind of cold.
I should also note that both times I reset the code, when I restarted the car, it stalled right after starting. I restarted and went on my way just fine. It's the only two times I can think of that the car has ever stalled on me.
I suppose I could also just ride it out and see if it goes away when it warms up a bit.
Edited by charm
needed to add some more
If you have access to a real scan tool you can watch the rear O2 sensor switch... if it follows the front directly, the cat is bad... if it takes forever to change the sensor is bad. It should stay lean 80% of the time.
Fix the front exhaust gaskets first... extra air in the exhaust makes the car run richer... which will make the cat seem broken since it cannot clean it up as easy.
