Well I snapped the bolt head off that holds in the speed sensor into the knuckle. Now the speed sensor has no way to be secured on. Do I replace the knuckle or drill out that rusted welded bolt that snapped like butter after being soaked for 3 days in PB plaster. Its a 98 OBW 200K.
you're talking about the ABS sensor right?
if you ever remove one without shearing the head off, please tell me...well nevermind, i won't believe you!
i've never *removed* one without shearing the stupid head off yet, very annoying.
let me tell you my "fix" that no one here will like. i drill and tap a smaller hole in the center of the original and just use a smaller bolt. it's not going anywhere.
given that the sensor itself actually gets *welded* to the hub, here's my "logic" for all the anal folks to complain about. the housing gets stuck to the hub, and the sensor gets wedged into it's bore, i go with the notion that it's not going anywhere once it's seated. and it's a non load bearing part.
shucks,i've had drivers front have all the bolts come loose at once and the ring tumbled around while driving.:eek:
glad i don't have to deal with abs anymore..
