87jewbaru Posted January 28, 2009 Share Posted January 28, 2009 This is what i am working with. A 1990 Jeep Comanche, Never mind the rear bumper, I broke it so i am going to remove it. This is the basic idea of my build. Diagram A is the part that goes right behind the cab, I am going to run it a little above the cab so that I can add a front exo later. Am I going to need to reinforce the frame where it mounts? If so what are your suggestions? Diagram B is from the back. The blue is the frame. The red is where it mounts to the frame. What do you guys think, Any suggestions? Next question I started building myself a bumper before I wrecked my truck, the bumper is the width of the bed made out of 3/16 wall 2x5. Should I use it as a base in the back? like diagram B, or should I build something new that is narrower? Mind you that I am going to full widths. I am going to add fenders later so that it is streetable. Link to comment Share on other sites More sharing options...
rtcaravan Posted March 26, 2009 Share Posted March 26, 2009 plans are not to bad. i wouldn't mount it to the bumper. run a brace at the end of the frame rails (2x4 box side to side) above your shackles. this will strenthin the frame and give you a great place to weld your roll bar. if your going to put the bed sides on make it narrower so they fit like factory. are you building it for off-road use? if your counting on your roll bar to save the body if rolled over i would add more bracing. keep it as safe as possible. Link to comment Share on other sites More sharing options...
frogstar7055 Posted March 26, 2009 Share Posted March 26, 2009 Behind the cab I would mount it to the top of the frame instead of the sides. Link to comment Share on other sites More sharing options...
rtcaravan Posted March 27, 2009 Share Posted March 27, 2009 yes, weld everything on top of the frame it will be much stronger. i didn't see the side mounting on the drawings. Link to comment Share on other sites More sharing options...
