So I got the car jacked up, sitting in neutral running. And the wheels are turning :confused:. WTF??? It's in neutral so what gives? Did a quick search and found pretty much every problem but mine.
If I push the clutch in slightly, they stop turning.
Tried adjusting the clutch cable, maybe I didn't adjust it enough?
Oooooohhh... ok I thought that because it was in neutral it was COMPLETELY disengaged but I guess I was wrong. Thanks for clearing that up!!
OK another question. I noticed that the front left wheel wasn't turning (should have mentioned that in first post), only the right front was. So once the car was off I grabbed the left front to turn it and it feels difficult to turn. I JUST put a new axle in on this side, does it take time for the axle to grease itself internally? Or maybe my brakes are dragging?
