87 loyale won't rev above idle
Check for engine vacuum. If your catalytic converter is clogged or has melted down the engine will not be able to expel exhaust gasses, so it wont be able to rev up. A clear sign of this is no vacuum. Easy to test, just loosen exhaust from heads to let the engine breath. If this is your problem car will run much better.
