mattri Posted January 29, 2009 Share Posted January 29, 2009 87 loyale non turbo has new plugs cap/rotor will start and idle but doesn't want to rev. Any ideas? Will get some some more info and post with it later. Thanks, Matt. Link to comment Share on other sites More sharing options...
Frank B Posted January 29, 2009 Share Posted January 29, 2009 Carbureted engine? When you press the throttle, does the engine grown and try to stall or does it just keep idling? It could be the float sticking in the carb. Link to comment Share on other sites More sharing options...
EvilDead Posted January 29, 2009 Share Posted January 29, 2009 Intake has a leak if not carbed, or vacuum leak someplace. Make sure everythig is good and snug while you're in there. Link to comment Share on other sites More sharing options...
mattri Posted January 30, 2009 Author Share Posted January 30, 2009 Yeah it's carbed. I thought they'd gone EFI by 87, 86 being the transition year. It was a car I was interested in but turned out to be an auto so no matter. Thanks to those that replied, Matt. Link to comment Share on other sites More sharing options...
abog Posted January 30, 2009 Share Posted January 30, 2009 Check for engine vacuum. If your catalytic converter is clogged or has melted down the engine will not be able to expel exhaust gasses, so it wont be able to rev up. A clear sign of this is no vacuum. Easy to test, just loosen exhaust from heads to let the engine breath. If this is your problem car will run much better. Link to comment Share on other sites More sharing options...
EvilDead Posted January 30, 2009 Share Posted January 30, 2009 ^^^ Another good idea. Just don't run it without them unhooked for too long, ya will burn internals up real quick. Link to comment Share on other sites More sharing options...
