lmdew Posted January 30, 2009 Share Posted January 30, 2009 I'm looking for the small coolant hoses for a 95 2.2 that go from the coolant manifold to the Throttle Body, Throttle Body to the IAC and IAC back to the Coolant Manifold. I can't pull them up on 1st Subaru Parts or Rock Auto. Looked under Cooling, Engine .... Thanks Using straight hose works but the bends are not the best. Link to comment Share on other sites More sharing options...
idosubaru Posted January 30, 2009 Share Posted January 30, 2009 i just bypass the throttle body myself. easier to avoid those tight bends, one less hose, two less connections, two less clamps = more reliable. i've noticed no difference at all in performance, but it only gets down to negative 10 degrees where i live:lol: Link to comment Share on other sites More sharing options...
lmdew Posted January 30, 2009 Author Share Posted January 30, 2009 Great idea. Link to comment Share on other sites More sharing options...
edrach Posted January 30, 2009 Share Posted January 30, 2009 I'm looking for the small coolant hoses for a 95 2.2 that go from the coolant manifold to the Throttle Body, Throttle Body to the IAC and IAC back to the Coolant Manifold. I can't pull them up on 1st Subaru Parts or Rock Auto. Looked under Cooling, Engine .... Thanks Using straight hose works but the bends are not the best. Call 1stsubaruparts directly; ask for Jason in Parts and he'll get you the hoses you need. Toll free 1-866-528-5282. 1stsubaruparts used to be Auburn Subaru, but now is separate and not associated with them anymore I believe. But Jason is still there and very helpful to help bypass the crappy software on the website. Link to comment Share on other sites More sharing options...
Gloyale Posted January 30, 2009 Share Posted January 30, 2009 Car quest carries 1/4 inch heater/coolant hose. No need for them to be OEM subaru parts, bulk hose wirks fine here. Link to comment Share on other sites More sharing options...
