thermalsurfing1 Posted January 30, 2009 Share Posted January 30, 2009 (edited) so i removed the coil overs a while ago and put the longer ranchos on we added a 4" lift to the rear to level it out . now the rear diff seems low and the tires are angled. i can lift the rear very easily and the tires with straten out. what the heck is going on ? help !! i think my torsion bar is broke or a need a diff lift. Edited January 31, 2009 by thermalsurfing1 Link to comment Share on other sites More sharing options...
bratman18 Posted January 31, 2009 Share Posted January 31, 2009 yeah sounds like the torsion bar is no good. You should put the rear coilovers back in. Link to comment Share on other sites More sharing options...
thermalsurfing1 Posted January 31, 2009 Author Share Posted January 31, 2009 wont the coil overs be to short with the 4" lift. can i buy longer coil overs from a aftermarket place ? Link to comment Share on other sites More sharing options...
bratman18 Posted January 31, 2009 Share Posted January 31, 2009 yes they will be short but that's why you build some blocks for the rear. I think there is a how to on subarubrat.com or subazero.com There is a good pick on subazero.com Go under subaru build and suspension. Link to comment Share on other sites More sharing options...
88RxTuner Posted January 31, 2009 Share Posted January 31, 2009 +1 on building spacers and installing coil-overs. This would be the best route to go in the long run anyway, given the ease of maintenance and 'tunability' of the shocks if you decide to change them. Possibly build new spring seats on the aftermarket shocks? Maybe one of those "Ebay" universal coil-over kits? (no experience here, just an idea...) Link to comment Share on other sites More sharing options...
The Beast I Drive Posted January 31, 2009 Share Posted January 31, 2009 I can build you a set of 4" brakets to mount those coilovers, as long as you are using EA82 rear coilovers. PM me if interested. -Bill Link to comment Share on other sites More sharing options...
Phizinza Posted January 31, 2009 Share Posted January 31, 2009 Coilovers screw up the suspension travel you can get out of the torsion bar setup. I'd say get a new set of torsion bars and keep you good long travel shocks. Also you might want to check the torsion bar adjuster bolt, as there are two bars and if both are broken I find that hard to believe. Perhaps someone took the adjuster out so the torsion bars didn't work so they could run coilovers with it? Link to comment Share on other sites More sharing options...
