OK- I'm pretty sure I know the answer to this question, but I'm getting ready to pull an EJ22 from a '97 Impreza (built 6/96) w/auto trans. to put in a '97 2.5GT Legacy Wagon 5 speed. Can someone verify that it doesn't matter that it's coming out of an Impreza instead of a Legacy? Are there any other parts I'll need to swap? Thanks.
It'll work.
You'll need the flywheel from 2.5.
Maybe have to mess with charcoal canister lines - I forget. But if you do it's not bad.
You won't have the PS line bracket as stated here - no biggie.
You will need the Ypipe off the 2.2
Search around here. Very common swap.
Legacy/Impreza doesn't seem to matter. For a while the JY's around here charged Less for Impreza's so that's what I used.
Dave
