rear washer spray adjustment
I've never checked to see if this is true for Subarus but, on every other car I've owned, the washer fluid comes out of a little ball mounted in a cup sort of like a ball point pen's tip. I was able to change the angle of spray by sticking a needle in the output hole and rotating the little ball a bit. You might give that a shot.
Good Luck!
Will-
